What should the lesson of FIRST be? Work within your resources to build the most effective machine that you can--and, at the same time, work to increase those resources. - Billfred [more]
I had an interesting thought about attaching helium balloons to our robot, and then detaching them in the middle of a match. The only rule I could find regarding the issue is G19:
However, the field is defined as:
Which means that leaving things ABOVE the field doesn't really count?
Could somebody please clarify?
What possible reason could you have for doing this?
"You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
