Thread Tools |
Rating:
Display Modes |
Re: Tower Tracker 1.0
Just wanted to post and say we ran a modified version of TowerTracker on a Jetson TK1 at the Greater Kansas City regional this weekend with great success. Thank you Fauge and team 3019 for sharing your work.
Congrats one being able to use it succesfully! |
Tower tracker is now award winning! Shout out to team 1806 Swat! Congrats on going 15-0 at this week's regional! Proof the program can change robots. If anybody needs help with implementing it I am more then happy to help. Pm me with questions.
Hello. We are having trouble running it on a raspberry Pi. We I try to run the exported jar I get an no opencv_java310 in Java.library.path. Would love to be able to use it for this regions just having some trouble getting it to work. Opencv 310 is installed and compiled on the Pi.
Hey!
when you are building the java file, make sure to include the opencv jar file in your class path. An easy way to do this is to using the -cp command while building. Doing this will work: java -cp /home/pi/opencv/build/bin/opencv-310.jar TowerTracker.jar This configures the class path to include the jar for OpenCV which is the error that you are facing. /home/pi/opencv/build/bin is the default location for the jar. If you need any more help with this. Feel free to PM me! I went through this same process last week ![]() Last edited by axton900 : 31-03-2016 at 18:29. |
Hey guys!
How do you calibrate the camera, exactly... I have opened up GRIP and got the RGB values of a setup in which the goal is clear and then took those values and edited the Lower and Upper bounds respectively but have been getting 0 contours.. Thanks! |
#7
Do you have a link to your code? Also you might want to check that the lower and upper bounds are in BGR order instead of RGB. It took me a while to figure that out.
#8
I am using an untouched version of TowerTracker and I found RGB values on GRIP and I put them as the Upper and Lower Bounds in BGR order and I still am detecting nothing. Any suggestions? Thanks!
#9
Can you use imshow to display a window of what your original, resize, and threshold Mat's look like? That might help.
#10
I am not sure how to do so. I am running the Java code provided. I remember your team discussing this on another thread. How exactly do you guys calibrate because that seems to be the problem.
Thanks! |
#11
To calibrate the camera, what we did was save the first image it grabbed and then downloaded it onto our pc. Then we brought it into GRIP and found the right RGB values. Then we just plugged it into lower and upper bounds arguments. It worked for us. We did have an issue where we had a really bright image right when the camera started. My best guess is because the camera lens is still adjusting its white balance or something like that. But when just ran the code again after the camera was on for a second. This wasn't a problem in competition because your robot is on a while before the match starts.
#12
Elaborate on the finding the perfect RGB values. Would you find these to be good?
#13
I would actually recommend doing your calibration in the HSB/HSV color space, as it separates color(H) from brightness(B/V) which means you can get a more robust calibration that will working in many different lighting environments (as the color your LEDs output shouldn't change) provided you turn your camera's exposure down.
