Go to Post If your robot doesn't work, it doesn't matter, because the robot is really meaningless, in the long run. What is the important thing, the reason we're all in FIRST then? To better our understanding of Science and Technology, and hopefully make the world a better place. - Ian W. [more]
Unread 14-03-2016, 10:01
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Re: Banging the driver station
Originally Posted by TDav540 View Post
While I don't believe that teams should run into the wall in autonomous, I don't find it a serious enough issue (especially with velcro on the driver station) to warrant a card.
The problem is that I've seen stories where even though the operator consoles were attached with hook and loop tape, the force of a 120-pound robot hitting at 10 mph was still enough to send them flying. That kind of shock force is enough to damage hard drives and jostle hardware connections enough to cause BSODs. Just browse the threads here and you'll see teams that lost expensive laptops that fell down, or lost matches because their laptop was damaged after a hard shock.
Generally speaking the expectation that "it's going to happen" is warranted, for many of the reasons already stated. But look at the goals of auto this year compared to, say, last year. Last year one could certainly expect robots to bump and bang the driver station while trying to get a 3-tote auto stack. But you would not expect, except by freak accident, a robot to aim itself directly at the driver station wall and charge at it. But this year that's exactly what you're supposed to do.
If FIRST's answer going forward is "deal with it" then I would recommend at the very least adding more hook and loop tape to the operator console (not just one strip) or provide other options for mounting, like straps or bolts. They should also provide rookie teams with SSD-based netbooks.
Unread 14-03-2016, 10:15
TDav540's Avatar
TDav540 TDav540 is online now
Questionable Decisionmakers
AKA: Trevor Davidson
FRC #1648 (G3 Robotics)
TDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud of
I completely agree with this idea. Having more options to secure the driver station is always a positive.
2015-??: FRC 1648, G3 Robotics
2016 Carver Division, Columbus District Chairman's Award, Albany District Finalists
Georgia Tech, Class of 2019; Emcee, Ref, and 2016 Technology Enrichment Presenter
2011-15: FRC 540, TALON 540 Godwin Robotics
Proud Alumnus and Supporter
2015 Newton Division, Virginia Regional Finalist Alliance Captain
2014 Curie Division, Virginia Regional Engineering Inspiration
2013 Curie Division, Virginia Regional Engineering Inspiration
Unread 14-03-2016, 11:02
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
As an engineer, I prefer to find a technical solution to the problem, rather than complain about it. Here are some resources to help.
Computer:
http://www.amazon.com/Lenovo-Ultra-D...ve+shock+mount
Cable strain relief:
https://www.tethertools.com/product-...le-management/
Note that there are 108 square inches of velcro at the drivers station for you to anchor your driver station to the shelf. Using published strength ratings, (http://qualitythread.com/Download/Ve...ty-Tapes-2.pdf) you should have 702 lb force in tension, and 810 lb force in shear to retain your drivers station. I'll suggest, in the kindest way possible, that teams whose drivers stations "fly off" the shelf perhaps aren't taking advantage of what they have been given.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 14-03-2016, 13:16
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Computer:
QFT.
FIRST has stated that impacts with the alliance station (especially during autonomous) WILL occur, and that the Velcro is there FOR THAT REASON.
I do agree that continuous purposeful impacts to the drivers station during teleop can be construed as 'Damage to the field' and penalized that way but teams should plan for some impacts to happen.
___________________
- Tennyson, Ulysses
Unread 14-03-2016, 13:27
philso philso is offline
FRC #2587
Computer:
The laptop linked is rated for resistance to vibration and temperature (thermal) shock and is not claimed to have resistance to mechanical shock. It probably will be more tolerant to mechanical shock than most laptops.
