Go to Post To the ball knockers, I salute you. - Brandon Holley [more]
  #31   Spotlight this post!
Unread 14-03-2016, 09:16
Levi Madden's Avatar
Levi Madden Levi Madden is offline
Student
FRC #1987
Levi Madden is on a distinguished road
Re: Banging the driver station
At Kansas City, the refs said that if your drive station did fall in auto, you could pick it up, without the penalty for crossing the line.
  #32   Spotlight this post!
Unread 14-03-2016, 09:38
philso philso is offline
FRC #2587
There is no guarantee that you are able to catch your laptop so it does not get damaged and leave your robot unable to compete.
  #33   Spotlight this post!
Unread 14-03-2016, 09:47
Sohaib's Avatar
Sohaib Sohaib is offline
AKA: Sohaib Nadeem
FRC #5036 (The Robo Devils)
Sohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of light
It is really simple to secure your driver station. Use the velcro. (hook side on your driver station) This has already been pretty common, but we were surprised to see no other teams were using clamps like we were. If you do go with this approach, make sure your driver station has an SSD, an HDD can be effected by the shock the "castle" wall may receive.
Another option is to use suction cups on the lexan "glass" of the driver station.
2014 Season:
- Drive Coach
- Rookie All-Star Award (GTR-E)
2015 Season:
- Driver
- Deans List Semi-Finalist (GTR-E)
2016 Season:
- Driver
- Alliance Captain (GTR-E)
  #34   Spotlight this post!
Unread 14-03-2016, 10:01
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Originally Posted by TDav540 View Post
While I don't believe that teams should run into the wall in autonomous, I don't find it a serious enough issue (especially with velcro on the driver station) to warrant a card.
The problem is that I've seen stories where even though the operator consoles were attached with hook and loop tape, the force of a 120-pound robot hitting at 10 mph was still enough to send them flying. That kind of shock force is enough to damage hard drives and jostle hardware connections enough to cause BSODs. Just browse the threads here and you'll see teams that lost expensive laptops that fell down, or lost matches because their laptop was damaged after a hard shock.
Generally speaking the expectation that "it's going to happen" is warranted, for many of the reasons already stated. But look at the goals of auto this year compared to, say, last year. Last year one could certainly expect robots to bump and bang the driver station while trying to get a 3-tote auto stack. But you would not expect, except by freak accident, a robot to aim itself directly at the driver station wall and charge at it. But this year that's exactly what you're supposed to do.
If FIRST's answer going forward is "deal with it" then I would recommend at the very least adding more hook and loop tape to the operator console (not just one strip) or provide other options for mounting, like straps or bolts. They should also provide rookie teams with SSD-based netbooks.
  #35   Spotlight this post!
Unread 14-03-2016, 10:08
kmodos kmodos is offline
AKA: Alex
FRC #1126 (SparX)
kmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to behold
Originally Posted by AWoL View Post
What other sensors are you going to use to easily get distance information?
Encoders work fine when there is no slippage, however there is quite a bit this year.
  #36   Spotlight this post!
Unread 14-03-2016, 10:10
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Originally Posted by orangemoore View Post
All actions have consequences.
Regardless of intention, if you prevent another team by your direct (including autonomous) actions from playing to their full potential you deserve a penalty.
Not reading the rules and updates and understanding the consequences is also an action with consequences.
While the head referee is the final interpreter of the rules, they cannot change them & are supposed to interpret them as written. There are no rules against hitting the field hard enough to dislodge driver stations. A bit of grey area for egregious or intentionally damaging conduct, but that is a high bar to cross.
Having said that, intentionally ramming the field with the intent of dislodging driver station is certainly against Gracious Professionalism.
  #37   Spotlight this post!
Unread 14-03-2016, 10:13
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
We are running our autonomous based on time with adjustments through smart dashboard for the various defenses. We are not using full speed for any of them.
  #38   Spotlight this post!
Unread 14-03-2016, 10:15
TDav540's Avatar
TDav540 TDav540 is offline
Questionable Decisionmakers
AKA: Trevor Davidson
FRC #1648 (G3 Robotics)
TDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud of
I completely agree with this idea. Having more options to secure the driver station is always a positive.
2015-??: FRC 1648, G3 Robotics
2016 Carver Division, Columbus District Chairman's Award, Albany District Finalists
Georgia Tech, Class of 2019; Emcee, Ref, and 2016 Technology Enrichment Presenter
2011-15: FRC 540, TALON 540 Godwin Robotics
Proud Alumnus and Supporter
2015 Newton Division, Virginia Regional Finalist Alliance Captain
2014 Curie Division, Virginia Regional Engineering Inspiration
2013 Curie Division, Virginia Regional Engineering Inspiration
  #39   Spotlight this post!
Unread 14-03-2016, 11:02
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
As an engineer, I prefer to find a technical solution to the problem, rather than complain about it. Here are some resources to help.
Computer:
http://www.amazon.com/Lenovo-Ultra-D...ve+shock+mount
Cable strain relief:
https://www.tethertools.com/product-...le-management/
Note that there are 108 square inches of velcro at the drivers station for you to anchor your driver station to the shelf. Using published strength ratings, (http://qualitythread.com/Download/Ve...ty-Tapes-2.pdf) you should have 702 lb force in tension, and 810 lb force in shear to retain your drivers station. I'll suggest, in the kindest way possible, that teams whose drivers stations "fly off" the shelf perhaps aren't taking advantage of what they have been given.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
  #40   Spotlight this post!
Unread 14-03-2016, 13:16
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Computer:
QFT.
FIRST has stated that impacts with the alliance station (especially during autonomous) WILL occur, and that the Velcro is there FOR THAT REASON.
I do agree that continuous purposeful impacts to the drivers station during teleop can be construed as 'Damage to the field' and penalized that way but teams should plan for some impacts to happen.
___________________
- Tennyson, Ulysses
  #41   Spotlight this post!
Unread 14-03-2016, 13:27
FRC #2587
Computer:
The laptop linked is rated for resistance to vibration and temperature (thermal) shock and is not claimed to have resistance to mechanical shock. It probably will be more tolerant to mechanical shock than most laptops.
  #42   Spotlight this post!
Unread 14-03-2016, 14:16
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Originally Posted by rsisk View Post
It seems they would drive into the wall, turn and then shoot a low goal.
Question: Is this just part of the game play we should plan for? Or should this type of game play be made illegal?
I mean from my point of view it doesn't sound like they weren't doing it for the impact, it sounds like it was how they aligned with the goal. It would be one thing if they intentionally kept doing it harder and harder but if the goal is to score then the less time you spend running into walls the better you will do and that at a certain point they will just casually drift into a cool spot and take the shot.
As soon as they are just smashing the wall just for damage thats one thing, but it sounds like they didn't have any bad intent.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
  #43   Spotlight this post!
Unread 14-03-2016, 14:37
*Rachelle*'s Avatar
*Rachelle* *Rachelle* is offline
Coach, Scout Captain, Marketing
FRC #3787 (Wild Robotocats)
Team Role: Student
*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of
I don't mind the robots hitting the Driver Station Wall too much. We have Velcro on the bottom of the driver station, but I also set my clipboard and the co-driver his Xbox controller up there. My concern is when during Auto the Xbox controller and clipboard fell off and the co-driver and my immediate reflex reaction was to catch it before it hit the ground in order to avoid damage. Now during auto we aren't supposed to cross that plane and especially touch controllers.
I didn't catch if a foul was called, and the match was restarted anyways, but what do you guys think about the foul if it did happen? We put the controller in a different place after that, so is it one of those as long as a ref doesn't see it happening constantly?
FRC: 2015 Glacier Peak and Shorewood Event Quality Award, 2015 Shorewood Finalist, 3x 2015 Pit Safety Award and Hard Hat Pin Award
FTC: 2016/17 Interleague Winner, 2016/17 Interleague Think Award Winner, 2016/17 Interleague Control/Inspire Finalist
"You have to learn the rules of the game. And then you have to play better than anyone else."
  #44   Spotlight this post!
Unread 14-03-2016, 14:38
Robonut
AKA: Mr. Lam
Rookie Year: 2015
They specifically do allow you to touch the operator console for safety purposes (e.g. to rescue it).
  #45   Spotlight this post!
Unread 14-03-2016, 14:42
Rangel's Avatar
Rangel Rangel is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
I agree with others that teams should make sure they Velcro down stuff but I also firmly agree that yellow and red cards should be given to teams that repeatedly do it. There is a third of a field worth of error teams can have in their autos so that they don't smack into the wall as hard as they can. Teams need to take responsibility and make sure their auto works without tackling the station. Once or twice fine but the whole regional is unacceptable in my opinion. At that point it is either fully intentional or the team didn't bother or care enough to fix it. A team this week hit the driver station so hard it activated an e-stop and the match had to be replayed. Was that the field's fault or the robot's fault? I'm sure people might answer differently but I completely believe it to be the robot and team's fault.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
