Go to Post If you think life is fair, you are sadly mistaken. - R.C. [more]
Unread 20-01-2016, 03:57
OreNPluS OreNPluS is offline
FRC #1577 (Steampunk)
OreNPluS is an unknown quantity at this point
Using the Xbox One controller ?
The driver station support inputs from Xbox One controllers ? we think about getting new controllers and there is option we can get those.
Unread 20-01-2016, 07:22
Re: Using the Xbox One controller ?
I have not personally tested it, and I'm not aware of a test report from a beta team. XInput is the API reading the joystick, so I expect it to work. The joystick needs to communicate to the PC using USB, no wifi or other wireless comms.
If you have testing results, please post them.
Greg McKaskle
Unread 20-01-2016, 09:18
chubchub5577 chubchub5577 is offline
FRC #1802
chubchub5577 is an unknown quantity at this point
I use the Xbox One controller daily when coding in labview, my mentors personally like the Logitech F310 more because of the placement of the joysticks personally I love the controller and might even use it in competition, we will see. So far no input issues from the controller (Unless you count broken code hahaha) so if you like the controller I would say go all out and use it! Best of luck!!
Unread 20-01-2016, 10:20
Clayton Summerall's Avatar
Clayton Summerall Clayton Summerall is offline
FRC #4587 (Jersey Voltage)
Clayton Summerall is on a distinguished road
My team shut down my desire to use a Scuff or elite controller.....
Unread 20-01-2016, 11:01
Ok thanks for the answers, if we will get those we will post testing results
Unread 06-03-2016, 11:30
peterl peterl is offline
AKA: Peter Laser
FRC #1592 (Bionic Tigers)
peterl is an unknown quantity at this point
Did you find anything out yet? We were also wondering if the Xbox one controllers would work.
Unread 06-03-2016, 12:11
sanelss sanelss is offline
FRC #1658
sanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to behold
Yes it works just fine both the 360 and xbox one controllers, we're using one of each ourselves. The original oem ones you just plug in and run windows update to find the driver, the after market ones you may have an issue getting the driver installed since the windows update won't recognize them so you will have to find an older installer for the driver but then that will work.
if you're using labview I can share a vi that makes them MUCH easier to use too.
Unread 06-03-2016, 12:45
AKA: Peter Laser
That would be amazing, please share! We are having issues getting them recognized by the DS. Device Manager sees them, but the DS isn't, or is only seeing one instead of two.
Unread 06-03-2016, 12:47
AKA: Peter Laser
Originally Posted by peterl View Post
That would be amazing, please share! We are having issues getting them recognized in recognized by the DS. Device Manager sees them, but the DS isn't, or is only seeing one instead of two.
Also, we are hoping to use two xbox one's or two xbox 360's. I don't if that might be why it isn't working.
Unread 08-03-2016, 03:03
Arod192's Avatar
Arod192 Arod192 is offline
AKA: Andrew Rodriguez | Koala
FRC #1972 (Searing Engineering)
Rookie Year: 2015
Arod192 is an unknown quantity at this point
My team uses Xbox one controllers. Be sure to get the Xbox one micro USB cable that goes from the remote to the computer because my Samsung cable didn't work with the remote so I had to buy the special Xbox labeled one.
Unread 08-03-2016, 10:29
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
We tried the Xbox One controller and they worked.
But we use these:
http://www.gamestop.com/xbox-360/acc...ntroller/43229
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 14-03-2016, 12:11
jfitz0807 jfitz0807 is offline
FRC #2877 (Ligerbots)
Team Role: Parent
jfitz0807 is an unknown quantity at this point
We have been having trouble with our Xbox 1 controller. Alone it seems to be OK, but we have a second controller with more buttons. When both are plugged in, the DS often crashes. We switched Xbox1 controllers and it worked better. We thought it was bad firmware in the first one, but then the second one started behaving the same way. We borrowed an Xbox360 controller for the rest of the competition.
We were at WPI and showed it to Brad Miller, the WPILib guy. He was talking to the DS maintainer so at least they know about the issue.
Unread 14-03-2016, 12:17
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #3663 (CPR)
Team Role: Driver
zinthorne will become famous soon enough
We use xbox one controllers. They work great! We use 2 and both run just fine. Ours are the micro usb connection ones. The only problem we had was that our DS computer was not running Windows 10. Windows 10 contains the driver for the controllers automatically and detects them. If a you are running an older version of windows you have to download the driver from somewhere else.
