Go to Post There will always be a point in your FIRST experience when you realize you can get away with something that is against the rules. It is at that point when you have a choice to make about your own personal ethics, and what sort of example you will set for your students. - ToddF [more]
Unread 14-03-2016, 14:49
antillies85 antillies85 is offline
FRC #4680
antillies85 is an unknown quantity at this point
Re: 2016 match data
This is amazing! But I have a very newbie question for you. So looking at say MIKE's qualification match data, how would you use data to build a profile of which matches a team was involved with and the scores from that particular match? Would it be a pretty complicated set of vlookups to build that profile?
Thanks so much for compiling this! And we've been trying to look for ways to learn how to interact with the API but the tutorials are pretty thin. If you have any suggestions, that would be awesome.
Unread 14-03-2016, 15:31
Re: 2016 match data
In the qual match CSV, Columns E thru J contain the Team Numbers r1,r2,r3,b1,b2,b3.
Say you want to find all of Team 469's matches in Week2 MIKE2 event.
Insert a new column right after Column J. Now you will have a new blank column K.
Put the heading "Team469" in cell K1.
Put the following formula in cell K2:
=IF(COUNTIF(E2:J2,"469"),1,0)
Copy cell K2 all the way down.
Now each cell in column K contains the value "1" if 469 played in that match, or a "0" if they did not.
Select all the cells in the spreadsheet, and sort by column K descending. All the matches that 469 played in will be displayed at the top of the spreadsheet.
Is that what you were asking?
