Go to Post By the end of the year, I have a feeling that I'm going to know much, much more about the intricacies of orbit balls than I ever wanted to. - Jared Russell [more]
Unread 22-02-2016, 10:36
ChetRanjan ChetRanjan is offline
Chet Ranjan
AKA: Chet Ranjan
FRC #5404 (North Penn Montco Robotics)
ChetRanjan will become famous soon enough
Flaky Radio
There are two locations at which we test our robot.
At Location1, everything is hunky-dory. We get “green” on communications, Robot Code and Joystick and everything works as expected. (http://www.chiefdelphi.com/forums/at...d=14561553 68)
At location2, communication becomes flaky. We get half green and half red on communications. (http://www.chiefdelphi.com/forums/at...d=14561553 68) The %loss on communications shoots up from almost 0% to 75% and obviously the robot behaves erratically (http://www.chiefdelphi.com/forums/at...=14561553 68).
Would you have any insight as to what is going on with the radio at Location2? How do I debug the issue? Is there a way to circumvent the given situation and force persistent connection to the radio? Please let me know.
Thanks for your help.
Chet
ID:	20141  Click image for larger version
ID:	20142  Click image for larger version
Unread 22-02-2016, 10:39
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Flaky Radio
If your location based diagnosis is correct than it is most likely due to two different things
1) An excess of strong WiFi networks that are interfering with the communications of the router (an example of this would be the schools internet distribution network
2) EMF feedback (sometimes from certain heavy machines or if the room has a lot of non bouncable material eg aluminum)
Unread 22-02-2016, 10:48
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Re: Flaky Radio
Please post photos of the good and bad locations in the robot.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 22-02-2016, 11:12
Re: Flaky Radio
You can switch to 5GHz at the troublesome location if your laptop is 5GHz capable.
You can use InSSIDer to see what AP conflicts are active at your troublesome location.
Then you can browse to the OpenMesh and move it to the least used channel within the 2.4GHz band.
Unread 14-03-2016, 15:56
Chet Ranjan
AKA: Chet Ranjan
Re: Flaky Radio
Mark:
Along with insider I also used the Chanalyzer to perform the spectrum analysis and moved to a channel that was least used (with 5 GHz radio). That seems to have solved it. It took me a while because I don’t go to warehouse that often. Your help is really appreciated.
Best Regards,
Chet
