Re: 2016 match data
Thank you! Yes, my brother mentioned doing that as well. Thank you for confirming that this is a good way to go about this. I'm trying to use Tableau to compile data and visualize it all.
Thank you for your help! |
Re: 2016 match data
In Excel, a better way would be to write a simple macro to pick each match that 469 played in, and copy it to a new sheet. Quote:
Re: 2016 match data
But I've found the best way is to blend the data in Excel and then import into Tableau, which does require calculations and possibly macros. |
