Go to Post now now, there is no such thing as reading the manual too much. I read it every night just before I go to bed. - 663.keith [more]
Unread 14-03-2016, 16:09
Chito Chito is offline
FRC #5000
Chito has a spectacular aura aboutChito has a spectacular aura about
vinyl cuts not sticking to bumpers
Is any other team having problems with vinyl cuts not sticking to bumpers?
If you have, can you please tell me how you dealt with this issue.
Unread 14-03-2016, 16:18
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
Re: vinyl cuts not sticking to bumpers
We used some sort of heat transfer vinyl for our bumper numbers, but I'm not exactly sure where online we got it.
The edges started peeling up a little, so we hit it with a heat gun and pressed it back down with a credit card edge, and it worked beautifully. (We used Dacron sailcloth for the fabric)
Unread 14-03-2016, 16:56
Zyrano Zyrano is offline
AKA: Alvin
FRC #1967
Zyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to behold
Send a message via AIM to Zyrano
You need heat transfer vinyl and remember to cut it mirror, and you'd need a heat press to make it work...
Here is the material we use. http://www.signwarehouse.com/p/endur...5in-11ft-white
it takes 350degrees for 20 seconds, so more than an iron can normally do.
W.R.R.F. Board member, 2007-??
Mentor, 2007-??, NDSJ Robotics FRC Team 1967
Mentor, 2013-15 Evasive Robotics FTC Team 6223
Supporter, 2006-11, Bulldogs Robotics FRC Team 581
Supporter, 2007-??, Pioneer HS Robotics FRC Team 668
Supporter, 2011-??, Dark Matter FRC Team 2643
Student, 1999- GRT FRC Team 192
Unread 14-03-2016, 18:45
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
My team used heat transfer vinyl. I take classes off campus of my main school, where we have acess to a lot more technology, so we had a vinyl cutter I could use. I messed up cutting so I was able to use bumper scraps to practice ironing on the vinyl. I'm not sure the temperature but I tuned the iron to the right area so if I pushed down on each number for 30 seconds l, it would melt perfectly in. We took a lot of hits last weekend, and it scuffed the vinyl but hasn't peeled or truly messed it up.
*Note- I wasn't at the school that had the vinyl cutter and heat press so I used a normal iron for clothes.
Unread 16-03-2016, 02:08
MrsDitt's Avatar
MrsDitt MrsDitt is offline
AKA: Kathryn Dittmeier
FRC #1736 (Robot Casserole)
MrsDitt is on a distinguished road
It is important to match up the type of cloth you are using with the correct heat transfer product. For instance, the slick bumper material from Andy Mark is made of nylon, which is a difficult product to stick most heat transfer vinyl to.
This chart from Siser, manufacturer of Easy Weed heat transfer vinyl, shows the different types of product they make and what fabrics they work on. Only Easy Weed Extra, VideoFlex Glitter, and Glitter adhere to nylon, and it specifies "lightly siliconed vinyl," which I don't think describes the slick bumper material.
https://www.specialty-graphics.com/m...vinyl-tech.pdf
If you think it's the type of fabric you have, you might try swapping out your fabric for cotton duck cloth, widely available in red and blue at JoAnn Fabric. Use a coupon and it won't be too costly.
When vinyl type and fabric type are a good match, there are three other things that can affect the end product: proper temperature, dwell time, and pressure. Basic Easy Weed for cotton works at 305 degrees, requires medium pressure, and 10-15 seconds. We've had to go up to 320 degrees, heavy pressure (using a heat press), and 30-40 seconds for some heavy cotton fabrics.
Kathryn Dittmeier
Business/Media Mentor
Robot Casserole, FIRST Robotics Competition Team 1736
www.robotcasserole.org
#FRC1736
Unread 16-03-2016, 10:51
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Two words: Super Glue
It works for FRC Team 1501
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 16-03-2016, 11:10
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
We tried regular vinyl to see what it would do. If you heat up the fabric than heat up the vinyl a bit before sticking it, It will stay on very well.
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
