#16
Re: Lights to help aim
The keystone of any rock solid robot frame is welded-on Green LED rings, to be sure.
#17
#teamflashlight |
#20
I was really surprised to get the visibility and focus I got out of this little flashlight, which is roughly one inch in diameter and about 4 inches long. Last edited by Travis Hoffman : 03-14-2016 at 09:31 PM. |
#22
It looks like you should be able to connect the EN pin to a DIO pin on the RoboRio to turn it on and off. You would have to remove the 100kOhm resistor on the D15V35F5S3 if you are using an input (VIN) higher than 5 Volts. This would require that the RoboRio be able to set the EN pin in the High state or Low state 100% of the time. I would expect the software should allow this but I am not sure since I take care of the electrical and mechanical aspects of the robot. |
#23
For our second event, we will be working on ways to avoid the flashlight issue(such as pointing the beam at the bottom of the tower so it can't get people's eyes, as well as adding a dimming capability. As for the people asking which light we used, we used a pocket flashlight that one of our team members bought at a hardware store, I don't remember what the part number was exactly, but it was about 6" long before we chopped off the battery compartment. |
#24
Now that a precedent has been established - do we need to ask a Q&A to expand on what defines "distracting" and what criteria must be met for those of us who want to use vision processing. -s |
#25
Fixed
![]() But really, you guys were really bright at SWVA. Definitely lit up the tape. |
#26
Any guidance on using the Cree flashlight would be totally awesome... we do have a spike relay.... assuming that would be connected on the Relay port on the RIO and then a voltage regulator between the Spike and the light to get me to the right voltage should do right ? Any picture would be appreciated.
#28
We used the following: - LED Flashlight with zoom - DC-DC Voltage Converter/Regulator - Spike Relay The LED flashlight had internal circuitry that allowed for 3 modes (high, low, flash). We only wanted the high setting so we took the circuit board out and wired the LED board directly to the voltage converter. This made wiring much easier as the LED board fit cleanly back inside the original housing. More conveniently, we used the metal clip on this flashlight as a mounting bracket by reversing it and drilling out the hole a bit. Next, we locked the flashlight in the zoomed position using a zip tie. Finally, we used a bunch of hot glue to secure the wires inside the area where the battery would go. So, the full setup is how you described - Power Distribution Board > Spike Relay (with pwm wire connected to the Relay port on the RoboRIO) > Voltage Converter > Flashlight. FYI - We soldered all connections but lost power connection somewhere in our semifinal match during a BIG collision. We're still not sure what happened but we know it's the power because the relay still responds to the driver's commands. Sorry I don't have any photos because the robot is currently bagged up. I can also provide screen shots of our labview code if anyone's interested. |
#29
Thank you very much !!!! and yes LV screen shot would be totally awesome !
Thanks a bunch ! |
#30
Team TRx 145 would love to see screen shots of the LabView code!!!!
Thanks |
