Go to Post As for the rain... I got to test out my umbrella hat last year. Turns out, it actually works...until the wind blows it off. - Barry Bonzack [more]
Unread 14-03-2016, 19:35
TDav540's Avatar
TDav540 TDav540 is offline
Questionable Decisionmakers
AKA: Trevor Davidson
FRC #1648 (G3 Robotics)
TDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud of
Re: Banging the driver station
Originally Posted by Caleb Sykes View Post
Every team receives an ultrasonic sensor as a PDV. This is a perfect sensor to be used for not slamming into walls at full speed in auto. There are dozens of other sensors that cost less than $50 that could also be implemented to stop teams from driving full speed into walls.
There are legitimate reasons why teams might not be able to stop themselves from driving into walls, such as inexperienced programmers or lack of programming time with the robot. However a lack of free/affordable sensors is not one of them.
While you have a valid point about the cost of the device....
Originally Posted by Abrakadabra View Post
In the future, you might want to consider an ultrasonic sensor (relatively cheap, but prone to signal scatter from the diamond plate walls) or for a little more money, one of the new compact LIDAR units.
.....this is also true. Ultrasonics would probably help often, but they aren't a perfect system.
2015-??: FRC 1648, G3 Robotics
2016 Carver Division, Columbus District Chairman's Award, Albany District Finalists
Georgia Tech, Class of 2019; Emcee, Ref, and 2016 Technology Enrichment Presenter
2011-15: FRC 540, TALON 540 Godwin Robotics
Proud Alumnus and Supporter
2015 Newton Division, Virginia Regional Finalist Alliance Captain
2014 Curie Division, Virginia Regional Engineering Inspiration
2013 Curie Division, Virginia Regional Engineering Inspiration
