Go to Post This [Coach badge] means no-touchy the controllers. Even to save them from certain doom. - Kevin Sevcik [more]
  #46   Spotlight this post!
Unread 03-14-2016, 03:35 PM
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Re: Banging the driver station
Originally Posted by TDav540 View Post
...not every team has/can afford sensors...
... While I'm not saying that all rookies cannot afford sensors, many cannot...
Every team receives an ultrasonic sensor as a PDV. This is a perfect sensor to be used for not slamming into walls at full speed in auto. There are dozens of other sensors that cost less than $50 that could also be implemented to stop teams from driving full speed into walls.
There are legitimate reasons why teams might not be able to stop themselves from driving into walls, such as inexperienced programmers or lack of programming time with the robot. However a lack of free/affordable sensors is not one of them.
  #47   Spotlight this post!
Unread 03-14-2016, 06:18 PM
swaxman12345's Avatar
swaxman12345 swaxman12345 is offline
Team Member
AKA: Sasha Waxman
FRC #2512 (Daredevils)
Team Role: CAD
Rookie Year: 2015
swaxman12345 is an unknown quantity at this point
Originally Posted by tomy View Post
There was a robot at the Duluth Regional that would do this every time in Auto Mode. They went through the defense then went full power at the wall. There should be a rule against this.
Yeah. We accidentally ran into the wall once and dislodged an opposing driver station. They didn't have any tape or Velcro on their station but even so we got a yellow card. I think I'd be more inclined to issue a yellow card if it was repeated match to match, but that was the referee's ruling.
Beware the Kraken, Jebediah. - Bill Kerman
  #48   Spotlight this post!
Unread 03-14-2016, 06:54 PM
*Rachelle*'s Avatar
*Rachelle* *Rachelle* is offline
Coach, Scout Captain, Marketing
FRC #3787 (Wild Robotocats)
Team Role: Student
*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of*Rachelle* has much to be proud of
I don't understand why they would yellow card this. It was once from what you say, and they specifically warned all of us about driver stations being knocked off in in "Week .5" and that we should Velcro them.
"You should expect the opposing robots to drive at your castle wall at high speed during auto, slamming into it. If your operator console isn’t secured, it may go flying. There is a strip of hook and loop tape on the shelf in the player station that holds your operator console. You should consider putting a mating piece of hook and loop tape on the bottom of your operator console to help it stay put. See Section 2.2.3.1 of the Game Manual." - See more at: http://www.firstinspires.org/robotic....OwoXGJhj.dpuf
Egregious is supposed to mean severe, and the examples the FRC manual used are more along the lines of humans touching robots during a match, not robots hitting the driver station.
2015 Glacier Peak and Shorewood Event Quality Award
2015 Shorewood Finalist
3x 2015 Pit Safety Award and Hard Hat Pin Award
"You have to learn the rules of the game. And then you have to play better than anyone else."
Albert Einstein
  #49   Spotlight this post!
Unread 03-14-2016, 07:06 PM
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Originally Posted by *Rachelle* View Post
<snip>
From my perspective behind the driver station, the hits were egregious in the sense it was shocking and bad. Not sure how it looked from the ref's location.
They were also repeated when the robot was shooting for the low goal.
My drive team asked if we could do the same thing when we were on the field (our robot was built very tough) and were told that is not a strategy we would use whether legal or not.
The views expressed are mine and should not be construed to represent the views of anyone else.
  #50   Spotlight this post!
Unread 03-14-2016, 07:35 PM
TDav540's Avatar
TDav540 TDav540 is offline
Questionable Decisionmakers
AKA: Trevor Davidson
FRC #1648 (G3 Robotics)
TDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud of
While you have a valid point about the cost of the device....
Originally Posted by Abrakadabra View Post
In the future, you might want to consider an ultrasonic sensor (relatively cheap, but prone to signal scatter from the diamond plate walls) or for a little more money, one of the new compact LIDAR units.
.....this is also true. Ultrasonics would probably help often, but they aren't a perfect system.
2015-??: FRC 1648, G3 Robotics
2016 Carver Division, Columbus District Chairman's Award, Albany District Finalists
Georgia Tech, Class of 2019; Emcee, Ref, and 2016 Technology Enrichment Presenter
2011-15: FRC 540, TALON 540 Godwin Robotics
Proud Alumnus and Supporter
2015 Newton Division, Virginia Regional Finalist Alliance Captain
2014 Curie Division, Virginia Regional Engineering Inspiration
2013 Curie Division, Virginia Regional Engineering Inspiration
  #51   Spotlight this post!
Unread 03-14-2016, 07:57 PM
I'll admit I haven't used ultrasonics with the diamond plate on the field (I'll be able to tell you more after week 4), but I find it highly doubtful that the scatter will be so bad that the ~10 foot sensors from MaxBotix wouldn't see the wall at all when the robot is 4 feet away from it. If this is the case, our autonomous routines are going to have some troubles.
  #52   Spotlight this post!
Unread 03-14-2016, 08:03 PM
TDav540's Avatar
I don't either (not a programmer, aren't using them this year), so I wouldn't be able to make a definitive call either. I'm definitely interested to hear about it though.
  #53   Spotlight this post!
Unread 03-14-2016, 08:14 PM
Sounds good, I'll make sure to post an update on the Iowa regional thread, so check there or watch our matches if you want to see how it goes.
  #54   Spotlight this post!
Unread 03-14-2016, 09:47 PM
I know this thread wasn't supposed to be about autonomous, but since there's a lot of discussion about encoders losing counts, I figured I'd chime in with this: http://www.chiefdelphi.com/forums/at...3&d=1458005957
If 5089 could stop after catching that much air, it's a matter of tuning, not sensor selection.
  #55   Spotlight this post!
Unread 03-14-2016, 10:38 PM
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
...I thought this thread would be about having teams stop banging on the driver station during team announcements. I was disappointed.
Viva Olancho!
  #56   Spotlight this post!
Unread 03-14-2016, 11:07 PM
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to all
I see the announcers doing it more, not even considering the fact i have never seen it in any PNW event i have been to.
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
  #57   Spotlight this post!
Unread 03-14-2016, 11:09 PM
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Personally I have never had too much luck with the Maxbotix ultra sonic sensors. The reading always seemed to be very low resolution.
  #58   Spotlight this post!
Unread 03-15-2016, 12:01 AM
Resolution without filtering can sometimes be bad, but never horrible. With our running average filter, we have about 4-inch resolution. I suspect that a median filter would work better, so we might try that if we want better performance.
Regardless, even without filtering, it can pretty easily be used not to run full speed into walls.
  #59   Spotlight this post!
Unread 03-15-2016, 09:36 AM
maxnz's Avatar
maxnz maxnz is offline
Can't wait for next season!
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
Back in Lunacy they had bumpers on the alliance station wall. In hindsight, that may have been a good idea this year.
As a senior that will be leaving the team, I have to teach others how to:
1. Know the manual extremely well
2. Wire the robot
3. Organize the shop
4. Help people find parts when they need them
5. Find parts to order and give the detailed list to the coach in charge of buying the parts
6. Keep track of team updates, Q & A responses and FIRST blog posts
7. Be active on CD
8. Plan and execute drive team strategy
And more that won't fit on this list...
  #60   Spotlight this post!
Unread 03-15-2016, 11:05 AM
neshera's Avatar
neshera neshera is offline
Nesher G. Asner
AKA: Nesher G. Asner
FRC #1625 (Winnovation)
Team Role: Parent
neshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud of
Interesting thread.
What would the commenters think about a robot that, either in Auto or Tele-Op, unintentionally repeatedly rammed in to other robots at full speed, hard enough to damage/disable the other robot?
Would a notification that robots should be built to withstand high-speed impacts excuse such behavior?
Would a notification that robots should be built to withstand high-speed impacts absolve the ramming robot of yellow/red cards?
Would we condone a team building/driving such a robot?
My point is, the drivers' station equipment is something teams purchase, program, build, modify - just like our robots. It is not inspiring to see your hard work go down the drain because someone else found a task too daunting/difficult.
Our goal is to inspire students. Telling them it is their fault for not securing their equipment well enough, or that they didn't buy robust (read: expensive) enough equipment, or to just "deal with it" when entire matches or entire regionals are destroyed for them does not seem to me to be the right attitude.
Do not panic! All is well!
- Kevin Bacon in Animal House
