Go to Post So once and a while no matter how addicted you may be, try to think outside the 48'x24' box of FIRST. - Tytus Gerrish [more]
Unread 15-03-2016, 10:07
logank013's Avatar
logank013 logank013 is offline
System.out.println("Ready!");
AKA: Logan Kreisher
FRC #0234 (Cyber Blue)
Team Role: Scout
Rookie Year: 2015
logank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant future
Re: Balloons
Originally Posted by Jaci View Post
Screw these 10ft driver station poles, we've found the elusive "full field" webcam, suspended by balloons.
Haha. Couldn't one argue that it would be classified as a drone? That would then violate the admin manual. haha
Cyber Blue Season 2015
IN Indy District Chairman's Award Winner | IN Kokomo District Event Winner (With 135 and 3865)
IN Purdue District Event Winner (With 1024 and 2197) | IN District Championship Winner (With 1024 and 292)
WORLDS:
Archimedes Rank 3 After Quals. | Alliance #3 Captain
Archimedes Division Semi-Finalist (With 503,188, and 836)
Scouting is life. Excel is friend, not foe.
Unread 15-03-2016, 10:55
nate3538's Avatar
nate3538 nate3538 is offline
AKA: Nathan Dowden
FRC #3538 (Robojackets)
Rookie Year: 2015
nate3538 is an unknown quantity at this point
Re: Balloons
Originally Posted by tig567899 View Post
I had an interesting thought about attaching helium balloons to our robot, and then detaching them in the middle of a match. The only rule I could find regarding the issue is G19:
However, the field is defined as:
Which means that leaving things ABOVE the field doesn't really count?
Could somebody please clarify?
why? just why?
Unread 15-03-2016, 12:28
ProfessorAlekM ProfessorAlekM is offline
FRC #6190
ProfessorAlekM has a little shameless behaviour in the past
Re: Balloons
If your aiming for lower weight, you could fill balloons with helium and pop them, so then just the gas leaves and not the balloon itself.
Unread 15-03-2016, 12:40
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Re: Balloons
Maybe a variation on this strategy?
https://xkcd.com/689/
Unread 15-03-2016, 12:48
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
Re: Balloons
Keep G17 in mind as well (emphasis mine).
G17 ROBOT height, as measured when it’s resting normally on a flat floor, may not exceed 4 ft. 6 in.
during the MATCH, except during the final twenty (20) seconds of TELEOP where there is no height
limit when a ROBOT is fully contained by the opponent’s COURTYARD.
Violation: FOUL. If strategic, offending ROBOT will be DISABLED.
Nate
