Go to Post If the GDC doesn't want better teams to strap components on to other robots, they should design a game that doesn't require better teams to strap components on to other robots to win. - Tom Bottiglieri [more]
Unread 15-03-2016, 13:21
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: Offseason Video Review Pilot-Volunteers?
To the folks planning to experiment with video replay/review of challenged calls this year, please take a look at what Tristan and I wrote here: Related thread.
Unread 15-03-2016, 16:41
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Originally Posted by CalTran View Post
Not that I disagree with the prospect of video replays (though I have my own reservations about it), but where does the budget for the proposed 10 "necessary" 1080p cameras come from? I would much rather something like Ryan Dognaux's St. Louis set up that anywhere can set up at minimal cost.
My proposal isn't for the actual system that would be deployed to every field. It's a proposal for what's needed if you want to determine what sort of video replay system is needed. The goal is to answer the question: "what's the minimal setup needed to correct most incorrect referee calls" with data.
The best way to do this is to capture a bunch of data, and score every match under differing sets of assumptions using independent reviewers. Setting up a camera or two, and only allowing a maximum of 8 samples (one challenge per alliance, playoffs only) won't provide enough data to convince anyone to act.
The question I'm trying to answer is the percentage of time these variations prevent a review from correcting a missed call:
* lack of time sync
* low resolution
* slow shutter speeds (blurry)
* bad camera mounting (blurry)
* lack of depth of field (blurry)
* is 30fps adequate?
* bad point of view
For example, consider the FPS value. A robot moving at 10 feet per second moves 4" per frame at 30 frames per second. Is that enough that, in most situations, the correct call can be made?
I missed one thing on my list -- you need the match time, matched with the video.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 15-03-2016, 21:37
Jeanne Boyarsky Jeanne Boyarsky is offline
Java Mentor
FRC #0694 (StuyPulse)
Jeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud of
Originally Posted by patar8746 View Post
[*]You have ideas on rule variations that could be tried at these events and reasons why they might work better[/list]
In tennis, each player gets X challenges. If the video challenge is called in favor of the player, they keep the challenge. If the player is wrong, the challenge is used up.
With the "one challenge each" approach described in the first post of this thread, I think a good variant is "one incorrect challenge." That way, if the team has multiple bad calls, they can keep benefitting from them. However, they can't waste time with multiple silly ones.
One problem in tennis is that towards the end, a player will challenge just in case. Because the challenge is no good shortly, they might as well take a change and use it. Maybe FIRST can counter that with GP - only challenge if you really think the refs were wrong.
The other thing tennis does is have music and audience participation (clapping for drama) for challenges. Which adds some ceremony. I bring up tennis because the sport resisted video replays for a LONG time and they worked out well.
Note: I'm not sure what I think of video challenges in FIRST, but that's irrelevant to my posting ideas.
Team 694 mentor 2010-present, FIRST Volunteer and Co-organizer of FIRST World Maker Faire Tent
2012 NYC Woodie Flowers Finalist
2015 NYC Volunteer of the Year
Unread 15-03-2016, 23:28
smitikshah's Avatar
smitikshah smitikshah is offline
Drive Coach
AKA: Smiti
FRC #2869 (Regal Eagles)
Rookie Year: 2015
smitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond repute
I'd love to assist anyone in the greater NYC region at offseason events trying to implement this solution.
Unread 16-03-2016, 23:59
patar8746's Avatar
patar8746 patar8746 is offline
FRC+FLL Alum/Mentor/Brother/Geek
AKA: Patrick Naughton
FRC #3061 (Huskie Robotics)
patar8746 is on a distinguished road
I can help with any summer events in/near Chicago or other seasons in/near NYC
Huskie Robotics 3061: Drivetrain Engineering Lead ('14-'15), Pit Captain ('15)
Northern Lights Regional Champs ('13), Midwest Regional GP Award ('12, '14-'15) Semifinalists ('12) Quarterfinalists ('13, '14), Lake Superior Regional Quarterfinalists ('14)
2Train Robotics 395: College Student Mentor ('16-now)
NYC Regional Quarterfinalists ('16)
The opinions I express are mine alone and do not in any way represent the views of any teams or schools I am part of.
"Team 3061 needs a crowbar..." "Failure is always an option..." "drill bits are NOT endmills"
Unread 22-03-2016, 11:20
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
I think their suggestions wasn't that 10 cameras should be the solution, but that we should use 10 cameras during this testing phase to try various angles and determine the maximum amount of cameras needed.
That still doesn't address the fact that an off-season event may not have access to 10 cameras (or a system to accept and record all those inputs), but maybe they can crowdsource that. Have up to 10 teams bring in a camera that's up-to-spec.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 22-03-2016, 12:18
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
A challenge in tennis is also completely automated and only takes a couple of seconds to complete. The result could be displayed before the player finishes signalling that they want to challenge. The drama is what takes most of the time, sort of like the Project Runway 20+ second, "You're out!" drumbeat music at the end of the episode. Here, it really would take some time to review, more like an NFL game with the ref having to go "under the hood".
I'm also trying to envision a "challenge coupon" when most teams don't fully understand how timeout and backup robot coupons work.
I'm interested in seeing where this goes though. Evolution is a wonderful thing in a sport as complex as this one.
Nate
