Go to Post It's super-ironic that a question about searching was found via searching. Whodathunk? - Brandon Martus [more]
Unread 15-03-2016, 15:13
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Re: Check your Anderson battery connectors
Originally Posted by aphelps231 View Post
If you take a sharpie and draw a line around the hose right by the connector to display where it should sit in the connector you can easily check for this issue by simply looking.
Great idea. Our hoses are all black which makes this a bit more difficult to spot but now we have a great reason to use a different color next time.
(If only they sold purple air hoses, to go with our team branding...)
Unread 15-03-2016, 17:24
aphelps231's Avatar
aphelps231 aphelps231 is offline
Andrew Phelps
FRC #1318 (Issaquah Robotics Society)
aphelps231 has a spectacular aura aboutaphelps231 has a spectacular aura about
Just use a silver or gold sharpie! That'll actually be easier to see than clear tubing (we have clear blue tubing) with a black sharpie.
team1318.org
2016: Flight Director, Alliance/Match Strategy
2015: Mechanical Lead
2013-2014: Fabrication
2016: 2x district finalists, Quality, DCMP Entrepreneurship Awards
2015: 3x district winners, Innovation in Control, Creativity, Team Spirit awards
2014: Galileo Division finalists, PNW District Championship winners, 1x district winners, District Chairman's, Innovation in Control, Entrpreneurship awards
2013: Entrepreneurship award
Unread 15-03-2016, 19:54
Had a good one at L.A. last weekend. Team comes to the field for their match, tries turning it on in queue... NOTHING. Reset the breaker. Same result. Match almost ready to start. They plug in a battery from their partners, and the lights go on--at which point, the field staff proceeded to help them get the new battery secured and get the robot onto the field.
I never did hear what the root cause was...
Unread 15-03-2016, 20:16
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
We had an entirely different problem. Two matches in a row, our battery connector actually separated from the connector on the robot. Both times, it happened after going over the rock wall the second time.
The part that bugs me the most is that we had hours and hours of practice, and this never happened. Also, the connectors on those batteries and the one on the robot were properly constructed, and they are just as hard to pull (wiggle) apart as those on any of our other robots.
The first match, when we pulled the robot off the field, we wiggled the connector and the robot turned back on.
The second match, everyone on the drive team checked to make sure the connectors were properly seated. When we pulled the dead bot off the field, the battery connectors were at least 3/8" away from being fully seated.
Being dead for two of nine matches really sucks. Fixed by zip tying the connectors together.
Unread 16-03-2016, 11:47
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
I have been told for years that the SB50 connectors should be zip-tied together, but still don't quite agree.
If you find the connector pulling apart, SOMETHING is doing it. It won't happen spontaneously.
Your wires may be too short and/or your battery may be moving around within the robot. Both are problems that should be corrected by something other than adding a zip tie.
Someone always says "I've seen matches where the battery fell out and was dragged by the power cables across the field." If that happened, I'd rather have the connector come apart and disable the robot. You're going to get an E-stop anyway.
If zip-tying the connector makes a problem go away, you are really masking the problem. You have something wrong with the connection. The SB-50 connectors are very reliable and are designed for exactly this purpose.
That doesn't mean they can't fail, but failure is usually due to wear, mis-assembly, or abuse. You can't take them for granted. You need to check them and spot any potential problem. It all comes down to attention to detail.
The fact that they come pre-assembled doesn't mean that one can't be mis-assembled. The mating surfaces inside can be scratched and pitted by connecting things with clip leads, etc. (This is why the rules now state that battery chargers must be fitted with a matching SB-50 connector.)
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 18-03-2016, 17:54
rammsey's Avatar
rammsey rammsey is offline
Octo-π-rates
FRC #3502
Rookie Year: 2015
rammsey is on a distinguished road
I myself, along with the other drive team member when we put the robot on the field. Checked the connection, tugged on it, wiggled it. It was seated in there for good. We made sure it was not going to pop out like our previous match.
But then we go over a rock wall (not even at full speed if i remember correctly!) and boom, out for the whole match.
Back in the pits, we tug on it, wiggle it around, bend it, do everything possible. Drop the robot from 5 inches multiple times. Nothing! D:
Nothing like this has happened during any practice where we basically bashed the robot into defenses every which way.
Like you say, there maybe an underlying cause, but I guess we have to wait till our next regional to do further inspection. But even if we do fix the issue, definitely still going to use zip ties, can't risk it.
Unread 19-03-2016, 08:21
philso philso is offline
FRC #2587
When you drop and bash your robot, you can only determine that you may have some loose connections. You will have a hard time determining which connections are bad by doing this. To find the bad connections, you really need to methodically check each and every connection point, starting from the terminals of the battery, to look for loose connections. Do not stop if you have found one loose connection. It is quite possible that you have two or more. You also have to treat the crimp of the contact in the connectors as a separate connection point to be checked apart from checking that the contacts are actually connecting. You seem to be focusing only on the battery connectors.
Unread 19-03-2016, 20:29
rammsey's Avatar
Octo-π-rates
FRC #3502
Rookie Year: 2015
Because that's what our problem was 2 of our matches.
After each of those matches, when going to take the robot off the field, you could see that the battery connector was not seated in right. Even though before, like I had said. We made sure it was in there properly.
Rest of our matches we used zip ties so there was no chance of it getting unseated and we had no issues.
We just can't seem to figure out how that connector could have come loose going over rock wall those two matches.
Unread 19-03-2016, 20:47
How is your battery secured??
Unread 19-03-2016, 21:14
AKA: CAAAAAD
Here's a bad picture, but it's the best I could find.
There is velcro strapping holding the battery down into a "box" of sorts. In neither of the two matches where the connector separated did the velcro become undone. It's pretty hard to get the battery in and out, you could even say that it's a "press fit."
All of our battery leads are that long, so the battery would have to be launched up 6 inches to pull the connectors apart.
The best theory that I came up with is that it has something to do with the robot-side connector being bolted solidly to the frame (the "attacking side" that hits the defenses before anything else.)
Name:	Screen Shot 2016-03-19 at 9.05.17 PM.png
ID:	20394  Click image for larger version
Name:	Screen Shot 2016-03-19 at 9.05.17 PM.jpg
Unread 19-03-2016, 21:18
Thank you, but... please use JPG for photos, not PNG.
Unread 19-03-2016, 21:25
rammsey's Avatar
Octo-π-rates
FRC #3502
Rookie Year: 2015
Any reason why? I don't see anything wrong with using PNG
Unread 20-03-2016, 15:41
FRC #2587
The pictures really help people understand your situation.
The loops in your battery cables are long enough that the movement that is possible should not cause a good pair of connectors to come apart. How much force is needed to pull them apart? Try pulling at different angles. I don't see where your bumpers end up. Is it possible that another robot is hitting the battery wires? It seems that the constant in this is the connector on the robot side. Have you tried replacing it? Try putting painters tape so part of it is on the battery and part of it is on the bracket. Put other pieces so they are on one of the battery wires and the frame next to it. If anything is moving more than a few millimeters, the tape on it should tear and give you some clues.
Unread 20-03-2016, 17:08
rammsey's Avatar
Octo-π-rates
FRC #3502
Rookie Year: 2015
How much force is needed to pull them apart? Try pulling at different angles. clues.
We tried tugging on it pretty hard, and at all different angles. It is not at all easy to just pop that connector out.
The inside of the bumper comes right up against the outside face of the aluminum on the other side of the connector. Sorry if I'm not explaining it properly, we don't really have good pictures.
And both times the connector did dislodge, it happened during the second (this really baffles us) crossing of the rock wall. So no robot was hitting the connector at the time.
Unread 20-03-2016, 17:09
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
I'm not sure that this will alleviate the problems that some teams are experiencing regarding connections and Anderson connectors, however, for the past 10 years or so we require all new connectors to be back-filled from the wire side with hot glue. This helps with stability issues sometimes related to those who continue to lift the battery by the cables (WRONG) or separate the connectors by pulling on just the cables.
_____________________________________________
Last words before magic smoke appears: "There, that oughta work!"
2016 Utah Regional- Engineering Inspiration
2016 Utah Regional- Dean's List Semi-Finalist- Ed O'Connor
2016 Utah Regional- Dean's List Semi-Finalist- Emily Ferrari
2016 Utah Regional- 3rd seed
2016 SBPLI Regional- Finalist, 6th seed
2016 SBPLI Regional- Gracious Professionalism Award
