Go to Post Blowing out the transmission on your mini-van while hauling a trailer 700 miles from home is not fun. Trust me on this. - dlavery [more]
Unread 15-03-2016, 19:01
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Re: Drive forward to x inches
Originally Posted by acrilex View Post
Thanks,
I do understand the logic within this, we had a code with this kind of calculations, even slowing down when approaching at less than 5 inches, but the real problem is to actually make it work with PID, as I see many other teams are using this and it works perfectly.
Acrilex
So this is basically PID? Or really just P. You probably don't need I and D for driving a distance. You probably can't get much more accurate than within an inch anyway (from what we have found. But every robot is different).
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 15-03-2016, 22:34
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If you aren't interested in arriving at a spot with precision, you can simply drive forward and turn off the motors when you reach the desired number of clicks traveled.
That is, turn on the drive, then each pass of your loop, check the distance traveled and turn the motors off when you reach the desired count. You WILL overshoot if you do this, but probably not by much. If you figure out how far you coast after stopping the motors, just apply a bit of Kentucky windage and turn off the motors that much early.
Unread 15-03-2016, 22:51
ArchdukeTim
Kinda defeats the purpose of encoders though, doesn't it? Timed drive will do the same.
Unread 15-03-2016, 23:29
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
You will want to use WPILib's built in PIDController class for this.
I am assuming you are doing command based programming. If not, the same lines of code still apply, just in a different structure.
One thing to keep in mind is that PIDController will run its calculations in a separate thread. That means that you will need to call driveToDistance() once, and then continuously be checking if the PID is done yet with a different method. This fits in nicely with the command based structure, where you can put driveToDistance() in the initialize method, and do the check in isFinished().
public class Drivetrain extends Subsytem {
   public PIDController distancePIDLeft;
   public PIDController distancePIDRight;
   public Drivetrain() {
      distancePIDLeft = new PIDController(kP, kI, kD, RobotMap.driveTrainEncoderLeft, RobotMap.driveTrainLeftController, 20);
      distancePIDLeft.setAbsoluteTolerance(2); // Sets the tolerance, in the same units as your encoders, for how close to the target the PID needs to get to be considered finished
      distancePIDRight = new PIDController(kP, kI, kD, RobotMap.driveTrainEncoderRight, RobotMap.driveTrainRightController, 20);
      distancePIDRight.setAbsoluteTolerance(2); // Sets the tolerance, in the same units as your encoders, for how close to the target the PID needs to get to be considered finished
   //enables the distance PIDs and sets them to the given distances
   public void driveToDistance(leftDistance, rightDistance) {
      distancePIDLeft.enable();
      distancePIDLeft.setSetpoint(leftDistance);
      distancePIDRight.enable();
      distancePIDRight.setSetpoint(rightDistance);
   //if the both distance PIDs have completed, returns true and disables the PIDs
   public boolean atDistanceTarget() {
      if(distancePIDLeft.onTarget() && distancePIDRight.onTarget()) {
         distancePIDLeft.disable();
         distancePIDRight.disable();
         return true;
      } else {
         return false;
