Go to Post ...if you say "AndyMark" three times we show up... - Billfred [more]
Unread 15-03-2016, 18:17
ROULT ROULT is offline
AKA: pepemanboy
FRC #4403 (ROULT)
ROULT is an unknown quantity at this point
Axis camera IP changes during the game
We have configured the axis camera according to the instructions in WPILib 2016.
At the beginning of matches, the camera has effectively an IP corresponding to our team's number (10.44.3.5) but at the half of the game, it changes to something like 192.168...
Has anybody faced the same issue or knows how to solve it?
Thanks in advance for your help and time.
Unread 15-03-2016, 18:19
TylerS's Avatar
TylerS TylerS is offline
AKA: Tyler Stark
FRC #1747 (Harrison Boiler Robotics)
TylerS will become famous soon enough
Re: Axis camera IP changes during the game
Are you using DHCP to assign the axis camera IP or is it static? I recommend going static and retesting to see if that resolves the issue.
Purdue University 2019 - Aerospace Engineering
2016 - Team 1747 - Design & Build Mentor
2015 - Team 303 - Coach/Build Captain
2014 - Team 303 - Build Captain
2013 - Team 303 - Driver
2012 - Team 303 - Programming Leader
Unread 15-03-2016, 18:37
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
There's a setting in there that has it fall back to a 192.168 IP by default if it can't acquire or loses its DHCP assignment.
You can turn that off. Make it either DHCP only or Static IP only.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 15-03-2016, 19:08
mhaeberli mhaeberli is offline
FRC #3045
mhaeberli is on a distinguished road
When making it static only, should one specify a router (like 10.30.45.1, or 10.30.45.129)?
Thanks,
Martin Haeberli
(de-)mentor, FRC 3045 Gear Gremlins (formerly SWAT)
Unread 15-03-2016, 19:32
kiettyyyy's Avatar
I've had good luck of setting it to 10.xx.yy.250 on actual fields at events I've CSA'd at.
Static IPs are the last resort. We're typically able to get them all fixed up while using mDNS and DNS.
-Kiet Chau
www.team1538.com
Unread 15-03-2016, 20:02
The field DHCP serves addresses in the .20 to .199 range if I remember correctly.
So static addresses for cameras or other IP devices can use .10 to .19 safely.
Unread 15-03-2016, 20:25
FRC #3045
The Axis camera setup page:
http://wpilib.screenstepslive.com/s/...an-axis-camera
for the 2016 control system says you can use the range .3 to .19 safely for fixed IP addresses.
Martin Haeberli
Unread 15-03-2016, 21:16
By FRC convention static IP addresses use .1 for the radio, .2 for the roboRIO, .4 for an AP to work with the robot radio as bridge, .5 for the DS laptop Ethernet port, .6 for a separate programming PC, .9 for at home DS wireless port, .11 for the first IP camera.
staying somewhat with the conventions makes it easier for others to help you debug, but that's all.
Unread 15-03-2016, 22:05
BenjaminWard BenjaminWard is offline
Programming/Controls
FRC #0612 (Chantilly Robotics)
BenjaminWard is an unknown quantity at this point
I want to point out that your Axis *should* always be available at axis-camera.local. It uses a similar mDNS setup as the robot, so anyone who has the driver station or any other mDNS software (Bonjour through ITunes, etc) will see the camera there.
Unread 15-03-2016, 22:08
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
This is what worked for us. Prior to us figuring this out (but after our IP address that we used in the shop stopped working) we would scan the IP range before every match, find the camera, and enter it in the camera feed. This worked, although it was just another annoying thing on our already huge list of annoying things to do to set up for a match.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 15-03-2016, 23:24
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
Ours didn't work the entire first day. The FTA's tried to get it working but it needed a static ip and we had to set up the windows host file to force axis-camera.local to 10.29.59.11 (our camera's static ip). Just wouldn't be seen on the dashboard until we forced windows to see it. Mdns just wasn't cutting it.
Unread 16-03-2016, 08:12
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
[minor rant]
It's very unfortunate that using static IPs is has become obfuscated. It pretty much cost us the first 3/4 of our first event as I stupidly believed that static IPs wouldn't work and/or were against the rules. It would be nice if the documentation was explicit, or at least it said somewhere that it is okay to do it if you follow these guidelines.
[/minor rant]
[important part]
After I read on chiefdelphi.com that people were using static IDs and it was indeed allowed, I then looked for what IDs we could use. That wasn't easy to find. When I finally found what I was looking for, it is stupidly simple. So here it goes:
1) Find the documentation for the FRC control system from 2014 (or earlier). 2) Set the IPs as described. 3) Profit
[sub minor rant]What bothered me is that they could have just said "you can continue to use the same static IP ranges from past years".[/sub minor rant]
For those without past years' documentation, here it is:
Set roboRIO to 10.xx.yy.2
Set driver station to 10.xx.yy.5
Set camera 1 to 10.xx.yy.11
Set camera 2 to 10.xx.yy.12
(where xx.yy is your team number, so 2112's roboRIO would be 10.21.12.2 and team 51's would be 10.00.51.2).
Unread 16-03-2016, 09:27
It's wrong (slightly). You should not use .4.
This is the address of something on the field (router, AP interface, etc.) that is set as the gateway for the roboRIO as part of the DHCP address served by the field (you can see this if you USB tether to the robot and pull up the web interface without turning the robot off after a match.
Unread 16-03-2016, 09:38
Originally Posted by Chris Hibner View Post
[minor rant]
[/minor rant]
It's documented in this years documentation. http://wpilib.screenstepslive.com/s/...g-at-the-event
As documented at the link above, the driver station netmask must be 255.0.0.0 or else it won't connect to FMS.
Unread 16-03-2016, 09:40
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Another observation from this, and also having major pain in the a$$ with mdns in our setup, still to be "working" but no root cause of why Aaron spent two hours in our pit on Thursday at Waterford.. I feel for you Chris.
Please note that once your radio is programmed at the event, the DHCP server is turn off on your robot radio. The field is the only DHCP server while at the event.
So when you are in your pit, and testing there is no DHCP server to hand out IP addresses, so everything kind of defaults back to the 169. address space. For others this seems to work... For us, not so much...
When we were in the pit at Waterford, I used an old dlink configured to our home settings, when I needed to test and program. (which was all the time)
Thanks for the info on the static IP's
The sooner we get behind schedule, the more time we have to catch up.
