Go to Post Meh, wear safety glasses. - Mike Schreiber [more]
Unread 15-03-2016, 19:25
kyle_hamblett's Avatar
kyle_hamblett kyle_hamblett is offline
Hamby
FRC #1073 (The Force Team)
kyle_hamblett will become famous soon enoughkyle_hamblett will become famous soon enough
Getting out of tight places
This weekend, I finally got to test the robot on an official field. While I have a pretty good understanding of how it works, I was completely stumped by one scenario I found myself in.
The robot got stuck right up against a wall, and I tried for a good 20 seconds to get myself away from the wall. Drivers that have similar drivetrains, how do you find yourselves getting out of a situation similar to this?
Unread 15-03-2016, 19:27
ToMoPAnae's Avatar
ToMoPAnae ToMoPAnae is offline
AKA: Patrick Fischer
FRC #3620 (Average Joes)
Team Role: Driver
Rookie Year: 2015
ToMoPAnae is a glorious beacon of lightToMoPAnae is a glorious beacon of lightToMoPAnae is a glorious beacon of lightToMoPAnae is a glorious beacon of lightToMoPAnae is a glorious beacon of light
Re: Getting out of tight places
What kind of drivetrain do you have? And what wall were you stuck against?
Unread 15-03-2016, 19:36
Hamby
My bad for not specifying.
We have a 6 wheel tank drive with 8 inch pneumatic wheels and a 3/16" center drop. The entire robot is 28*32 with the short ends being the front and back.
Unread 15-03-2016, 19:43
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
So, if you're trying to do a spin move (move both sticks in opposite directions) to get out and that isn't working, maybe try moving only the side of the robot that isn't touching the wall to turn and then drive away. I guess I'm kind of confused about the situation you are describing.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 15-03-2016, 19:44
inorbert inorbert is offline
Build Captain and Driver
FRC #5811 (BONDS)
Team Role: Driver
Rookie Year: 2016
inorbert is an unknown quantity at this point
Drive forward and away from the wall then backwards away, if you are even a inches or two away than you can just turn directly and get out
Unread 16-03-2016, 14:40
YoshiCity YoshiCity is offline
FRC #0133
YoshiCity is an unknown quantity at this point
Take advantage of the compression of your bumpers. You will always be able to force the robot so make some sort of angle with the wall, then maneuver from there. Great job at North Shore, it was fun playing with you guys.
Unread 16-03-2016, 14:44
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Getting stuck against a surface just means you need to reverse parallel park out of it or alternatively if you can follow the surface until a break you can do that.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
#GLITTERFORCEHYPE!
Play is for kids this is serious...
Unread 17-03-2016, 01:51
MetaEngineer's Avatar
MetaEngineer MetaEngineer is offline
Director of magic smoke
AKA: Barden
FRC #0246
MetaEngineer is an unknown quantity at this point
Out of curiosity, what gear ratio do you have? What tire pressures are you running? Technique can only do so much if the bot stalls motors long before it makes use of the traction it has available. Drop centers can become useless too if the center tires are under inflated to the point where all the outer wheels scrub anyways.
