Go to Post We have a lot of rookies, and I can't wait to see the inspiration on their faces. - Karibou [more]
Unread 20-02-2016, 12:21
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Required Update for Driver Station
Team Update 12 has a Required Update for the Driver Station to release 16.0.2
https://firstfrc.blob.core.windows.n...Updates/12.pdf
It says the update is part of the FRC 2016 Update Suite here:
https://decibel.ni.com/content/docs/DOC-46527
I downloaded the update, and installed it. However, the Driver Stations still read version 16.0.1
Unread 20-02-2016, 12:35
Re: Required Update for Driver Station
Mine says 16.0.2
Name:	DS version 16.0.2.jpg
Unread 20-02-2016, 12:44
Fixed. I downloaded the update again, and this time it is fine. I originally downloaded it when the Team Update was posted yesterday. They must have put out the Team Update before the new software was posted.
Unread 22-02-2016, 21:12
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
808.67 MB download? Seems kind of large for a simple DS update.
This link takes me to the 2016.1.0 update suite. Is there another link for the DS update?
UPDATE****
I went ahead and downloaded the 2016.1.0 update suite and after unzipping, installing and testing the DS now shows version 16.0.2 as it should. It took about an hour to do this update. SHEESH NI don't you do anything simple?
Unread 22-02-2016, 22:08
endreman0 endreman0 is offline
Programmer at Heart
AKA: Ian W
FRC #4131 (Iron Patriots)
endreman0 is an unknown quantity at this point
Hm... I can't download the update suite. I go to https://decibel.ni.com/content/docs/DOC-46527 and click the blue button in the bottom-right for "Download FRC 2016 Update Suite" and get 404.
Unread 23-02-2016, 08:22
Sorry about that. The update contains much more than the DS. It was much easier for them to rerelease the DS than to make a new small installer.
Greg McKaskle
Unread 28-02-2016, 17:38
btgdaniel's Avatar
btgdaniel btgdaniel is offline
FRC #1731 (Fresta Valley Robotics)
btgdaniel is an unknown quantity at this point
Greg,
Do we need to reprogram the RoboRIO or the PCM after installing the update?
Thanks,
Daniel
Team 1731
Catch the FeVeR ~ If You Can!
Unread 28-02-2016, 18:47
Just check the versions against what you currently have running according to the Driver Station Diagnostics tab:
  • For PCM/PDP/Jaguar/TalonSRX firmware - compare against C://Users/Public/Public Documents/FRC
  • For RoboRIO firmware - compare against C://Program Files (x86 as appropriate)/National Instruments/Shared/Firmware/cRIO (don't ask)/76F2/
  • For RoboRIO image - compare against C://Program Files (x86 as appropriate)/National Instruments/LabVIEW 2015 (yes, even you Java/C++ users)/project/roboRIO Tool/FRC Images
You should check each time a release comes out just in case you missed an earlier one or added a Talon/PCM/switched roboRIOs.
Unread 28-02-2016, 20:00
The DS release doesn't require any reprogramming or firmware updates.
Greg McKaskle
Unread 28-02-2016, 21:49
btgdaniel's Avatar
Thank you, sir!
Team 1731
Unread 02-03-2016, 13:04
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
Hi -
Our team installed this version over the previous DS install for 2016.
When exiting the driver station, a small dialog with the message "Resetting VI: DS UI.vi" appears and doesn't go away (we've waited up to 30min). It can't be closed, but can be killed via the task manager; the DS won't start again unless we kill this.
Anyone else seeing this? Doesn't seem to have any side effects, it's just odd behavior.
Thanks,
Ron
Team #2607 controls mentor
FIRST Mid-Atlantic Volunteer
FRC Team #2607 Mentor
Unread 15-03-2016, 19:14
nhalstead's Avatar
nhalstead nhalstead is offline
Noah H
FRC #5420 (Velocity)
nhalstead is an unknown quantity at this point
I am also encountering the same Problem with the Message after closing the Drive Station. Also the Drive station window does not go into the Full Screen Mode. It Just goes to the Windowed Mode. Not Sure what is going wrong.... Any Help would be Great!!!
Unread 15-03-2016, 19:48
If it's still in window mode there are buttons on the DS that switch it between full screen and window mode.
The buttons look like this:
http://www.chiefdelphi.com/forums/at...2&d=1422068986
