Go to Post try to be careful and follow good safe practices. - meaubry [more]
Unread 15-03-2016, 21:24
CHSDragonBots CHSDragonBots is offline
FRC #6108 (DragonBots)
Team Role: Electrical
Rookie Year: 2016
CHSDragonBots is an unknown quantity at this point
Exclamation Secret Passage Rules
I already know that you can enter your opponents secret passage but the question is can we enter our own secret passage to retrieve boulders? It doesn't say anything in the manual about what we can do in our secret passage.
Unread 15-03-2016, 21:26
joeojazz joeojazz is offline
FRC #5712
joeojazz is an unknown quantity at this point
Re: Secret Passage Rules
Yes you can go into your own secret passage to get boulders.
Unread 15-03-2016, 21:27
GaryVoshol's Avatar
Cogito ergo arbitro
Remember you can only enter your opponent's SECRET PASSAGE from the OUTERWORKS. Not from the NEUTRAL ZONE.
You are free to enter your own SECRET PASSAGE any way you want. Generally, what is not disallowed is allowed - with a notable exception being the BUMPER rules.
(since 2004)
Unread 15-03-2016, 21:31
ATannahill ATannahill is offline
AKA: Alex Tannahill
I think you mean courtyard, not outerworks.
You can enter and exit your opponent's secret passage from/to their courtyard. If you are entering from the outerworks than you are breaking through a shield.
wjd13 wjd13 is offline
FRC #4905 (Andromeda One)
Rookie Year: 2015
wjd13 is an unknown quantity at this point
Do you mean "Opponent's Courtyard" instead of outerworks?
Unread 15-03-2016, 21:34
GaryVoshol's Avatar
Cogito ergo arbitro
Yeah, enter the opponent's SECRET PASSAGE from the COURTYARD only.
I think I need sleep.
(since 2004)
Unread 16-03-2016, 10:04
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Basically you can use your SP anytime
You can use your opponent SP to and from their courtyard (But risk foul if touched by opponent)
You may not enter or leave opponents SP from Neutral (Foul)
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 16-03-2016, 13:05
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Think of it like a literal secret passage on a castle. You build all these defenses and walls to keep out enemies, but you are aware of secret passageways to get in and out of your own castle, so you are free to use them whenever. But when facing your opponent castle, you don't know where their secret passage is, or even if they have any, so as far as you know, it doesn't even exist.
It might have been interesting if they had added more facets to the game revolving around this. For example, what if, after you have successfully breached the castle defenses, you were then able to freely use the opponent secret passage (i.e. you've "discovered" it)?
