Go to Post Only Dave knows [if the 2010 game is designed already], and he aint tellin' but he'll happily feed you lots of red herrings. - Koko Ed [more]
  #31   Spotlight this post!
Unread 16-03-2016, 10:11
apm4242 apm4242 is offline
FRC #4242
apm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud of
Re: Lights to help aim
I don't have the code with me right now but I'll post screen shots later tonight.
If you can't wait, it's very similar to Team 358's Labview examples except ours uses a button toggle with "Off" and "Forward" as relay inputs. Don't forget to initialize in Begin.vi and end in Finish.vi.
Team 358's site seems to be down for the moment but Mark McLeod posted a .doc file with everything in it - http://www.chiefdelphi.com/forums/at...1&d=1454513427
  #32   Spotlight this post!
Unread 16-03-2016, 18:23
FRC #4242
See attached for LabView screen shots. A few notes -
Wiring the blue relay values to the selector was tricky. If someone knows a better way, feel free to correct this but here's what I did - right click on Relay Set and create a constant. Sever the connection between the new constant and the Relay Set. Connect the new constant to the Select and then wire the Select output to the Relay Set. Now the Select will accept and return blue values.
Selecting "On" and "Off" as the relay values did not work - the flashlight just quickly flashed and stayed off. We had to set it to "Forward" and "Off".
The Relay vi's are in the WPI Robotics Library > Actuators > Relay area.
The feedback nodes are finicky. Sometimes they don't turn green when wired to a Boolean on the first try and the arrows may need to be switched (right click). The button toggle code is straight out of Team 358's guide. I highly recommend it. It's the best.
  #33   Spotlight this post!
Unread 21-03-2016, 21:38
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
At my first attempt, the light was very bright and it look awesome. Then as soon as i remove power and re-apply the voltage, then it was very dimmed....
I figure i burn the LED or something like that so i proceeed to wire LED flashlight #2, and exactly same thing happen... at first it was bright and just like i want it, then, remove the voltage to the LED and reconnect and it turn on but was very light....
?Is there a cycle to reset or something weird I have to do?
  #34   Spotlight this post!
Unread 21-03-2016, 22:56
FRC #4242
Did you remove the round circuit board inside the flashlight? When functioning normally, there are 3 modes - high, low, flash. When you press the on/off button down half way, the mode switches and it remembers your last mode setting. The circuit board controls this function. It sounds like you might be simulating this by removing and reapplying the voltage.
  #35   Spotlight this post!
Unread 21-03-2016, 23:16
Coach Seb's Avatar
Rookie Year: 2015
Yes, we removed the circuit board and solder the LED directly to the voltage converter.
Anybody experience this?
  #36   Spotlight this post!
Unread 21-03-2016, 23:25
FRC #4242
Strange. We didn't see this. What flashlight and voltage converter are you using? Can you trace the source of the voltage drop with a multimeter to see if it's in the LED, relay, or spike? In other words, try checking if the LED is getting whatever the converter is supposed to put out
  #37   Spotlight this post!
Unread 22-03-2016, 00:20
ejscribner ejscribner is offline
Drive Team & Coach
FRC #2972
ejscribner is an unknown quantity at this point
Is the use of a laser pointer allowed on the robot? I feel like a laser would be exceedingly helpful for aiming and such.
  #38   Spotlight this post!
Unread 22-03-2016, 00:35
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
No. Typically, visible lasers are of Class II/III. The blue box on R9 says that you can only use Class I lasers.
  #39   Spotlight this post!
Unread 22-03-2016, 07:42
I don't know what kind of flashlight you started with. If it's a typical LED, then you have probably fried it by letting it have too much current. You need to have a resistor in series with it to set the current to a level where the LED will work properly.
  #40   Spotlight this post!
Unread 22-03-2016, 07:51
Coach Seb's Avatar
Rookie Year: 2015
I bought the exact same thing that was recommended by apm4242....
- LED Flashlight with zoom
- DC-DC Voltage Converter/Regulator
- Spike Relay
I'll check the voltage again... last night we had 10V on the spike relay, i did not check the voltage after the converter yet as we assumed we fried the spike... but yet between test it worked... still wondering...
  #41   Spotlight this post!
Unread 22-03-2016, 08:54
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I need to do more than a cursory look at electronics for legality, but is it possible to run two flashlights off of one spike relay? We'd like to run one flashlight off of the positive signal and a different flashlight off of the negative signal. Our electronics team has an idea of how it may work, but nothing concrete until they're back from Spring Break.
GitHub
  #42   Spotlight this post!
Unread 22-03-2016, 08:57
FRC #4242
I was under the impression that the voltage converter made the resistor unnecessary. Not using the resistor worked for us. For reference, this is what Alan is talking about - https://www.sparkfun.com/tutorials/219
  #43   Spotlight this post!
Unread 22-03-2016, 10:40
That will work fine. Use the Spike's M+ terminal as the "plus" for one flashlight, the M- terminal as the "plus" for the other, and connect the "minus" of both flashlights to the V- terminal where the ground wire is coming from the PDP. You'll need to know that setting the Spike FORWARD will turn on one light, setting it REVERSE will turn on the other, and setting it ON will turn them both on. OFF will of course turn them both off.
It used to be normal to run two pneumatic solenoid valves from one Spike in exactly this way.
  #44   Spotlight this post!
Unread 22-03-2016, 14:05
Ninjastahr's Avatar
Ninjastahr Ninjastahr is offline
FRC Member
FRC #3928 (Team Neutrino)
Ninjastahr is an unknown quantity at this point
Honestly, I would use a SuperBright LED ring. You just put it around the camera, and you can HSL/HSV Threshold the image to find the goal. Our team has used this technique and I know for a fact that it works, and doesn't *quite* blind people. Though, it does come close sometimes...
  #45   Spotlight this post!
Unread 22-03-2016, 16:09
Michael Hill's Avatar
I've been wondering...is there an advantage to using a flashlight rather than the LED ring? Is it just a cost/availability thing or is there some technical advantage as well? #KnowsNothingAboutCV
