Go to Post Don't forget Morgan Freeman will be at champs. Maybe he and Will are gonna freestyle it! - Nuttyman54 [more]
Unread 15-03-2016, 11:31
Zyrano Zyrano is offline
AKA: Alvin
FRC #1967
Zyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to behold
Send a message via AIM to Zyrano
Re: Check your Anderson battery connectors
So I found this... from here
http://www.powerwerx.com/anderson-po...es-50-amp.html
We have been using both pink and red ones, any chance this is a problem? or are the pink ones specific to FRC and the below does not apply?
SB Powerpoles are Color Keyed
A unique feature of the SB Series Powerpole housings are that they are keyed to only mate with the same color housing. For example, a gray color will only connect with the same gray color SB housing. The Red color will only connect to a red colored connector, etc. The exception for SB50 is the black housing which also mates with the gray housing.
This feature can be used to color code different voltages or systems and prevent accidental connection.
Read more: http://www.powerwerx.com/anderson-po...#ixzz42zCwM2yr
W.R.R.F. Board member, 2007-??
Mentor, 2007-??, NDSJ Robotics FRC Team 1967
Mentor, 2013-15 Evasive Robotics FTC Team 6223
Supporter, 2006-11, Bulldogs Robotics FRC Team 581
Supporter, 2007-??, Pioneer HS Robotics FRC Team 668
Supporter, 2011-??, Dark Matter FRC Team 2643
Student, 1999- GRT FRC Team 192
Unread 15-03-2016, 12:04
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
The pink sb50's we have been using are really red sb50's. From what I hear Anderson had too much pink plastic and donated pink versions of their red power poles to First.
Unread 15-03-2016, 12:22
Monochron's Avatar
Monochron Monochron is online now
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
So you are telling me that it's really lightish-red?
Unread 15-03-2016, 12:29
maxnz's Avatar
maxnz maxnz is offline
Can't wait for next season!
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
Yup. The blue box under R36 says that the pink connectors from the KOP can mate with the red connectors.
As a senior that will be leaving the team, I have to teach others how to:
1. Know the manual extremely well
2. Wire the robot
3. Organize the shop
4. Help people find parts when they need them
5. Find parts to order and give the detailed list to the coach in charge of buying the parts
6. Keep track of team updates, Q & A responses and FIRST blog posts
7. Be active on CD
8. Plan and execute drive team strategy
And more that won't fit on this list...
Unread 15-03-2016, 12:37
mhaeberli mhaeberli is online now
FRC #3045
mhaeberli is on a distinguished road
Shaif,
How were you using the webcam in conjunction with WPILib?
We had one, and then two webcams, but we were just streaming them through the router, not doing anything with WPILib.
Thanks,
Martin Haeberli
(de-)mentor, FRC 3045 Gear Gremlins (formerly SWAT)
Originally Posted by Shaif View Post
What seemed to be the problem for us (which we found out before our third last match) is that the cause for our radio to reboot was the webcam. I was told by another team WPILib's webcam support was the problem, and oddly enough turning off our webcam seemed to fix everything. We played like madmen during the last 3 matches and not a single "no robot communication" came up. Just to throw that out there is the leads weren't the problem.
Unread 15-03-2016, 15:08
aphelps231's Avatar
aphelps231 aphelps231 is offline
Andrew Phelps
FRC #1318 (Issaquah Robotics Society)
aphelps231 has a spectacular aura aboutaphelps231 has a spectacular aura about
This should be noted too: check all of your connections! For motors and pneumatics especially.
We unbagged our competition robot and were wiring up some electrical components, when we barely spotted a wire through the gap between two CIMs that had completely come out of an Anderson connector. Even worse was that it was for one of our drive CIMs. We had played through an entire district off of three motors! Good PID is both a blessing and a curse I guess...
Similarly in 2014 we learned that pneumatic tubes should be checked for a complete fit into ther fittings/connectors. Our pneumatic catapult experienced some issues in the semifinal matches of our second district event, which caused us to lose both matches. We didn't figure out it was a pneumatic connection that was loose until it blew completely out of the fitting during our second semifinal match. If you take a sharpie and draw a line around the hose right by the connector to display where it should sit in the connector you can easily check for this issue by simply looking.
team1318.org
2016: Flight Director, Alliance/Match Strategy
2015: Mechanical Lead
2013-2014: Fabrication
2016: 2x district finalists, Quality, DCMP Entrepreneurship Awards
2015: 3x district winners, Innovation in Control, Creativity, Team Spirit awards
2014: Galileo Division finalists, PNW District Championship winners, 1x district winners, District Chairman's, Innovation in Control, Entrpreneurship awards
2013: Entrepreneurship award
Unread 15-03-2016, 15:13
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Great idea. Our hoses are all black which makes this a bit more difficult to spot but now we have a great reason to use a different color next time.
(If only they sold purple air hoses, to go with our team branding...)
Unread 15-03-2016, 17:24
aphelps231's Avatar
Andrew Phelps
Just use a silver or gold sharpie! That'll actually be easier to see than clear tubing (we have clear blue tubing) with a black sharpie.
team1318.org
Unread 15-03-2016, 19:54
Had a good one at L.A. last weekend. Team comes to the field for their match, tries turning it on in queue... NOTHING. Reset the breaker. Same result. Match almost ready to start. They plug in a battery from their partners, and the lights go on--at which point, the field staff proceeded to help them get the new battery secured and get the robot onto the field.
I never did hear what the root cause was...
Unread 15-03-2016, 20:16
thinker&planner thinker&planner is online now
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
We had an entirely different problem. Two matches in a row, our battery connector actually separated from the connector on the robot. Both times, it happened after going over the rock wall the second time.
The part that bugs me the most is that we had hours and hours of practice, and this never happened. Also, the connectors on those batteries and the one on the robot were properly constructed, and they are just as hard to pull (wiggle) apart as those on any of our other robots.
The first match, when we pulled the robot off the field, we wiggled the connector and the robot turned back on.
The second match, everyone on the drive team checked to make sure the connectors were properly seated. When we pulled the dead bot off the field, the battery connectors were at least 3/8" away from being fully seated.
Being dead for two of nine matches really sucks. Fixed by zip tying the connectors together.
Unread 16-03-2016, 08:56
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Crooked cuts from wire cutters can exacerbate this problem, because they make it hard to fully seat the tube. Using a $7 tubing cutter from McMaster helps immensely.
Unread 16-03-2016, 09:51
ILAMtitan ILAMtitan is offline
Texas Instruments
AKA: Bart Basile
FRC #3005 (RoboChargers)
ILAMtitan will become famous soon enoughILAMtitan will become famous soon enough
This is a problem I first saw at TRR last August. It turns out that the issue was a broken connection at the battery terminal that was covered and being hidden by heat shrink. The #6 wires provided on the cables can work harden as they move back and forth and become brittle over time, leading to snapping the connection. Here's an example of a failing connection.
http://i.imgur.com/JRINTHW.jpg?1
I recommend inspecting these on a pretty regular basis.
Unread 16-03-2016, 11:47
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
I have been told for years that the SB50 connectors should be zip-tied together, but still don't quite agree.
If you find the connector pulling apart, SOMETHING is doing it. It won't happen spontaneously.
Your wires may be too short and/or your battery may be moving around within the robot. Both are problems that should be corrected by something other than adding a zip tie.
Someone always says "I've seen matches where the battery fell out and was dragged by the power cables across the field." If that happened, I'd rather have the connector come apart and disable the robot. You're going to get an E-stop anyway.
If zip-tying the connector makes a problem go away, you are really masking the problem. You have something wrong with the connection. The SB-50 connectors are very reliable and are designed for exactly this purpose.
That doesn't mean they can't fail, but failure is usually due to wear, mis-assembly, or abuse. You can't take them for granted. You need to check them and spot any potential problem. It all comes down to attention to detail.
The fact that they come pre-assembled doesn't mean that one can't be mis-assembled. The mating surfaces inside can be scratched and pitted by connecting things with clip leads, etc. (This is why the rules now state that battery chargers must be fitted with a matching SB-50 connector.)
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 18-03-2016, 17:54
rammsey's Avatar
rammsey rammsey is offline
Octo-π-rates
FRC #3502
Rookie Year: 2015
rammsey is on a distinguished road
I myself, along with the other drive team member when we put the robot on the field. Checked the connection, tugged on it, wiggled it. It was seated in there for good. We made sure it was not going to pop out like our previous match.
But then we go over a rock wall (not even at full speed if i remember correctly!) and boom, out for the whole match.
Back in the pits, we tug on it, wiggle it around, bend it, do everything possible. Drop the robot from 5 inches multiple times. Nothing! D:
Nothing like this has happened during any practice where we basically bashed the robot into defenses every which way.
Like you say, there maybe an underlying cause, but I guess we have to wait till our next regional to do further inspection. But even if we do fix the issue, definitely still going to use zip ties, can't risk it.
Unread 19-03-2016, 08:21
philso philso is offline
FRC #2587
When you drop and bash your robot, you can only determine that you may have some loose connections. You will have a hard time determining which connections are bad by doing this. To find the bad connections, you really need to methodically check each and every connection point, starting from the terminals of the battery, to look for loose connections. Do not stop if you have found one loose connection. It is quite possible that you have two or more. You also have to treat the crimp of the contact in the connectors as a separate connection point to be checked apart from checking that the contacts are actually connecting. You seem to be focusing only on the battery connectors.
