Go to Post If the left side of your brain controls the right side of your body then left handers are the only ones in "their right mind". - Al Skierkiewicz [more]
Unread 03-16-2016, 04:20 PM
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Re: 2016 HOTBOT
Mike / Ryan,
I assume there will be no tech notes posted (since I'm not there to make one ), but can you walk through the specifics of the design?
There looks to be a bike cable in there somewhere, not sure what crazy idea that is used for....
I really haven't talked to Jim in-depth about the design, so I'd love to know more about it and how you guys came up with it.
-Adam
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 03-16-2016, 04:29 PM
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Re: 2016 HOTBOT
Looks like 67 might be using a disc brake to hold pivot location for the arm?
We have two disc brakes on our 2016 robot, one to hold pivot location and one to hold elevator location. Both are critical for accurate shooting, as well as holding our hang position at the end of the match.
When you get the hang of it (no pun intended), they're pretty simple to integrate into a custom gearbox solution.
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 03-16-2016, 04:48 PM
Hot_Copper_Frog's Avatar
Hot_Copper_Frog Hot_Copper_Frog is offline
Public Relations Mentor
AKA: Megan
FRC #0503 (Frog Force)
Hot_Copper_Frog has a reputation beyond reputeHot_Copper_Frog has a reputation beyond reputeHot_Copper_Frog has a reputation beyond reputeHot_Copper_Frog has a reputation beyond reputeHot_Copper_Frog has a reputation beyond reputeHot_Copper_Frog has a reputation beyond reputeHot_Copper_Frog has a reputation beyond reputeHot_Copper_Frog has a reputation beyond reputeHot_Copper_Frog has a reputation beyond reputeHot_Copper_Frog has a reputation beyond reputeHot_Copper_Frog has a reputation beyond repute
Re: 2016 HOTBOT
The HOTBOT is looking great again this year! I'm disappointed I won't be seeing you at any districts this season, but hopefully we'll cross paths in Grand Rapids!
FLL Team Dark Matter 2002-2005 Student
FRC HOT Team 67 2006-2009 Student
FRC Superior Roboworks 857 & The Copperbots 2586 2009-2013 Mentor
FRC Frog Force 503 2014-Present Public Relations Mentor
Michigan Technological University Alumna
Air Quality Scientist
FIRST Enthusiast
Unread 03-17-2016, 11:54 AM
Legator91's Avatar
Legator91 Legator91 is offline
AKA: Ryan Legato
FRC #0067 (HOT Team)
Legator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud of
Send a message via AIM to Legator91
Re: 2016 HOTBOT
Thanks! Hope to see you at States Megan!
Michigan Tech: 2010 - 2014
University of Michigan: 2015 - Present
Mentor (FRC 67): 2015 - Present
Mentor (FRC 3771, 4363): 2011 - 2012
Student (FRC 67): 2007 - 2010
2010 World Champs (294, 67, 177)
2009 World Champs (111, 67, 971)
Unread 03-17-2016, 11:57 AM
Legator91's Avatar
AKA: Ryan Legato
Re: 2016 HOTBOT
-Mike
They work very well. We have incorporated bike brake cable into our designs before, but I believe this is the first time we have used a disc brake. Actuation is fairly easy, and they can support a large load.
Unread 03-17-2016, 11:48 AM
Legator91's Avatar
AKA: Ryan Legato
Re: 2016 HOTBOT
Mike / Ryan,
-Adam
Sure. The bike cable is used to actuate two bike disc brakes. We needed a way to ensure the robot would hang with the base parallel to the floor. We had several ideas, but then one of the mentors said "hey what about a disc brake". The brakes are mounted to the output shafts of the arm gear boxes. They are actuated by a pneumatic cylinder.
Mike already explained the shooter. It was really "cool", but as he said we had consistency issues with speed. We worked on improving gear mesh, wear, etc but no luck. So once we reveal the new design we can talk about it more.
Ball intake uses one 2 inch roller to bring the ball into the robot. We then have two conveyors that direct the ball towards center. One being powered, and the other driven by a cross over loop.
Other then that its just the usual HOTBOT chasis modified to fit the design for the game. We do use pneumatic wheels to aid in crossing defenses. We discussed tank treads, but after some research from past seasons we decided pneumatic wheels were better. They also were easier to package. We also use pneumatic shifting. So I guess we are starting to accept pneumatics into the design, when we never used to use them.
Full disclosure: Mike, Eric, and Jim were the leads this year on design. I was not able to commit as much time as I would have liked this season. I did help bounce ideas around, and aid in design and build where I could. Mike and Jim could go way more into detail.
Unread 03-17-2016, 12:45 PM
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Re: 2016 HOTBOT
Drive train is 2 CIM ball shifters 8wd with 8" AM pneumatic wheels, running 25 chain this year. Pneumatic system was added the Sunday before ship after concerns about our door lock actuator motor shifting robustness. We weighed about 100 lbs at this point and decided to bite the bullet. We use for shifting and arm brake actuation. Might be using a cylinder for portcullis actuation at Howell - Jim's working on something for this.
The arm has a 49:1 versa planetary into a double reduction gearbox 9.52:1. This was used over another planetary stage for durability concerns with this game. Then a chain reduction of 100:22. Saturday before ship we broke the teeth off the small gear in the 9.52:1 gearbox going over the rough terrain. Everything was replaced with steel gears before bag night and we started design on the brakes and a gas strut system. The rotor is on the gearbox output shaft before the chain reduction mostly because it packaged well, but it also gave an additional mechanical advantage to stopping the chassis. The main concern with that is chain strength - at Waterford we broke the arm chain on one side, and not just on a master link. We'll see how it plays out, but chain is easier to replace than gearboxes and we have some redundancy.
Hang is powered by 2 x 775 pros into 3:1 planetaries belt driving lead screws in both arm tubes. We had an issue with driving the lead screws out the end at Waterford, but that was mostly code and is resolved now.
Intake is a 10:1 BAG motor with a 30:24 reduction in belt. Same motor powers the centering belts through a bevel gear.
Overall weight right now is 107 lbs. The shooter change may eat up 0.5 lb or so, so we have some room to play.
Main focus for Howell improvements will be high goal and lots of practice time.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
