Go to Post Please think before you speak. - Cory [more]
Unread 03-03-2016, 10:54 AM
jwatson12 jwatson12 is offline
Mr. Watson
FRC #1025 (Impi Warriors)
jwatson12 is an unknown quantity at this point
GRIP Using Lifecam Issues (HSL Threshold needs a 3-channel input)
Error: HSL Threshold needs a 3-channel input
We are using the Lifecam with GRIP. We have set the Hue and look good on GRIP for publishing contour report. When publishing the Contour report we are getting the error HSL Threshold needs a 3-channel input. When we check the Outline Viewer client we see the contour report in network tables but no values for x/y coordinates. Has anyone run into this? Any feedback is extremely appreciated.
Unread 03-03-2016, 10:18 PM
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Re: GRIP Using Lifecam Issues (HSL Threshold needs a 3-channel input)
What version of GRIP are you using? A lot of people had a similar problem with v1.2, but it worked with v1.3-rc1.
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
Unread 03-14-2016, 08:12 PM
pavchag pavchag is offline
AKA: Paul Chaguine
FRC #5829 (AwtyBots)
pavchag has a spectacular aura aboutpavchag has a spectacular aura about
We are still having this same issue. We are using the LifeCam HD3000 with Grip and we can not get Grip to load to the rio without errors.
First we got 3 input error just like in this thread:
https://github.com/WPIRoboticsProjects/GRIP/issues/479
but none of the fixes helped.
Paul Chaguine
Awtybots FRC 5829 Head Mentor 2015-Now.
Discobots FRC 2587 Mentor 2010 - 2014.
Discobots FRC 2587 President 2009-2010.
Unread 03-16-2016, 05:07 PM
Sunny Bat Sunny Bat is offline
Programming Mentor
Sunny Bat is an unknown quantity at this point
I get this error whenever my camera is not being detected. Here's the stack trace in the GRIP UI.
Make sure that your camera is being detected -- you can view the image GRIP is reading from your camera by clicking the eye next to the Image object. If no image is shown, that means your camera is not being read properly. Check if any other programs (Skype or any video chat program, or mjpeg-streamer if headless) recognizes the webcam. You can also try switching USB ports and then restarting GRIP.
