Go to Post I think we can all remember, no matter our age, that we are always responsible for our own actions and reactions. - JaneYoung [more]
Unread 16-03-2016, 08:52
microbuns's Avatar
microbuns microbuns is offline
AKA: Sam Maier
FRC #4917
microbuns is an unknown quantity at this point
Rhino tread snapping?
Has anyone had issues with the rhino treads snapping? We busted one during a practice match when we started pushing another team.
We hope that it's just due to the fact that it was a heavily used track that has a lot of wear during build season and post build season.
Unread 16-03-2016, 09:57
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: Rhino tread snapping?
We at AndyMark have not heard of anyone else breaking a tread. These treads are rated at 600 pounds of break strength, with a safety factor of at least 2. The white (or clear) colored timing belts are reinforced with a continuous loop of steel cables.
Can you provide more information regarding how your tread broke?
Andy B.
Unread 16-03-2016, 11:03
microbuns's Avatar
AKA: Sam Maier
FRC #4917
Andy B.
Will do! Honestly, I still haven't heard the full details (it broke late last night, I wasn't there), but I expect to get the entire story (as well as a picture of the treads) today when I go in. My preliminary understanding is just that we went into a head on bumper to bumper collision with another robot, and in that collision we heard a snap. The carpet ripped underneath the robot - we aren't sure if that was due to the force of the tracks snapping or perhaps a symptom of the same issue that broke the tracks (maybe something sharp?). Our drivetrain uses 2 CIMs/side, but I don't remember the gearing (it's nothing crazy though).
However, that is comforting that they are rated for 600lbs - makes it sound more like a freak accident than anything!
Thanks for the support!
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
I too would like to see a photo of this snapped belt.
Unread 16-03-2016, 11:09
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
We had no issues with our treads they were flawless deep into back to back regionals....so that's 28 matches plus several practice matches.
We did have to replace all revision 3 with revision 4 pulleys
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 16-03-2016, 11:42
MrP_Hack's Avatar
MrP_Hack MrP_Hack is offline
FRC #3414 (Hackbots)
MrP_Hack is an unknown quantity at this point
Just curious if you HAD TO change all to rev 4 or you chose to change them to rev 4... in other words, did all of them break?
Unread 16-03-2016, 11:44
We went into competition with revision 3 (not my call I wanted then all changed out prior only had 4 and we ordered 8 more) and yes we ended up breaking all of them and replaced as we went with rev 4
Unread 16-03-2016, 12:42
Robomarfa Robomarfa is offline
FRC #5771 (Robohorns)
Rookie Year: 2015
Robomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to all
What is this Rev 4 and 3?
Unread 16-03-2016, 12:45
TylerS's Avatar
TylerS TylerS is offline
AKA: Tyler Stark
FRC #1747 (Harrison Boiler Robotics)
TylerS will become famous soon enough
Rev 3 is referring to the pulleys which shipped with the Rhino originally. Rev 4 is referring to the new pulleys that were designed to eliminate the failures that some teams were seeing with rev 3.
Purdue University 2019 - Aerospace Engineering
2016 - Team 1747 - Design & Build Mentor
2015 - Team 303 - Coach/Build Captain
2014 - Team 303 - Build Captain
2013 - Team 303 - Driver
2012 - Team 303 - Programming Leader
Unread 16-03-2016, 14:15
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
This is the main reason my team stopped using tank tracks back in 2007. We were using almost identical belts to the ones Andymark sells, and we would typically break at least one every competition we went to (and since the ones we ordered were custom, they were closer to $300 a piece).
After years of experimenting, we discovered that the issue seems to be caused by either too much or too little tension on the belts. Failure modes can also be caused by attempting to drive while getting pushed sideways by another robot.
Try adjusting the tension on your tracks using the turnbuckle and see if that helps (the tracks should be snug, not too loose or too tight). Also avoid situations where you get pushed from the side of the robot.
Finally, while it's certainly possible to build a reliable tank drive system, my advice to all teams using tank treads would be to make sure you have spare treads with you at your events, or you may regret it later.
Unread 16-03-2016, 14:56
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
We havent had issues with the blue rhino track belts. But we did have an issue with the black drive belts, we noticed during practice the robot drove to the right a little more and couldnt find out why, but the belt stretched somehow during a match and made driving almost impossible. Luckily we had extra belts we ordered. We learned that anything can and will break, so we keep extras of nearly everything at compeition. But after St Joe last weekend, a few teams I know learned to bring backups of 99% of your parents, even RoboRios can break for no reason.
Unread 16-03-2016, 15:11
microbuns's Avatar
AKA: Sam Maier
FRC #4917
So it appears that my story was a little bit off. It was NOT a head on collision - it was the same kind of situation cbale2000 describes:
Does anyone know what tension we should have the belts at such that they won't fall off but aren't dangerously tight?
Attached are photos of the snapped belt (I apologize for how huge they are).
Unread 16-03-2016, 15:47
aJASONt_angles's Avatar
aJASONt_angles aJASONt_angles is offline
Picture Taker of Sorts
AKA: Jason
FRC #4272 (Mavericks Boiler Robotics)
aJASONt_angles has much to be proud ofaJASONt_angles has much to be proud ofaJASONt_angles has much to be proud ofaJASONt_angles has much to be proud ofaJASONt_angles has much to be proud ofaJASONt_angles has much to be proud ofaJASONt_angles has much to be proud ofaJASONt_angles has much to be proud of
AndyMark Page for Track Drive Tensioning Here
Unread 16-03-2016, 17:36
RoboChair's Avatar
RoboChair RoboChair is online now
AKA: Devin Castellucci
From the visible damage to the side of the teeth/V-guide on the pulley face of the belt my guess is that the belt was forced to ride up onto the teeth of the sprocket dramatically increasing the belt tension and causing it to fail catastrophically.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 16-03-2016, 22:01
scca229 scca229 is online now
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
I'll admit that I had both my Dad (w/ 60) and Step-Dad (w/ 5207) working together like heck for several hours to build the drawbridges that didn't want to get built at my rookie FTA event at Arizona North Regional this past week. My Step-Mom is also a Mentor (w/ 60) and my Mom (working on her for 5207) came up to Flagstaff to see the event and her baby boy at his rookie FTA event. Didn't realize that bringing backup parents were a normality
On topic...that is an amazingly straight break, almost like it was cut by something.
Nate
