Go to Post what hint? - Electricia 1599 [more]
Unread 21-01-2002, 18:12
Ydnar's Avatar
Ydnar Ydnar is offline
#0932 (Circuit Chargers)
Ydnar is an unknown quantity at this point
Send a message via AIM to Ydnar
Post One word "gyro"
As you all know we all received those neat expensive gyro chips, but how would one go about using one of those, does anyone have any spec. about them if so please e-mail me the specs. @ biggestb59@hotmail.com i am literally dieing to figure out what the heck they can do....
-Come and go, and rise and fall with glory, maybe one day i'll be famous too
Unread 21-01-2002, 18:49
thedillybar thedillybar is offline
#0894 (Chargers)
thedillybar is an unknown quantity at this point
Send a message via AIM to thedillybar
The gyro (Yaw Rate Sensor) connects to the controller as a digital input and the PBASIC code interprets the input and determines what to do. Check out the Technokats Auto-Balance Code from last year if you're wondering how the PBASIC works for it. The code is in the White Papers or at the following link.
http://www.chiefdelphi.com/forums/pa...per&paperid=10
Unread 21-01-2002, 18:53
Jan Olligs's Avatar
Jan Olligs Jan Olligs is offline
#0448 (Crandroids)
Jan Olligs is on a distinguished road
Gyro sensor specifications
On the official homepage of FIRST, there is a 25 MB Acrobat Reader document called "Kit of Parts: Appendixes B-G" which contains in Appendix G all kinds of data sheets. To get there, click on "FIRST ROBOTICS" > "DOCUMENTS & UPDATES" > "Competition Documents" > "Kit of Parts: Appendixes B-G". More specifically, on pages G-14 through G-20 you will find everything on the gyro sensor, from technical specifications to an article that explains you how to use the sensor.
Jan Olligs
I have great faith in fools - my friends call it self-confidence. --- Edgar Allen Poe
Unread 21-01-2002, 22:31
I think you meant to say analog input, not digital. :-)
Unread 21-01-2002, 23:07
iscrc2 iscrc2 is offline
#0568 (Nerds of the North)
iscrc2 is an unknown quantity at this point
It made a lot of sense to use the gyro last year to help do the bridge balance, but are there good uses for it this year? Have any teams used the gyro as a "stabilizer" to help make their machine track a better line? E.g. in a tank style drive with variations in motors and transmissions perhaps 50% power equates to 50% in the left and 48% in the right. Would the gyro be useful for "fixing" that? We've messed with scaling in the code but it seems that one day its left, the next day its right.
Unread 21-01-2002, 23:25
Morgan Jones Morgan Jones is offline
Morgan Jones is an unknown quantity at this point
I believe at this point, my team is still planning on a somewhat complex steering system. I won't go into details, because it's our teams "secret". In any case, (since I'm the programmer) I was thinking I'd use the gyro to "kick in" the advanced steering system. Basically, if the robot's not turning, and it should be, apply the steering mechanism. I think that would be easier on the driver than having to manually apply it. Just an idea that others may also be able to use.
Morgan Jones
Team 578: Fairport High School/Gleason Works
Unread 22-01-2002, 09:44
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Question
I have no experience with the Gyro, but I wonder how sensitive it is to some of the bumping and bouncing that goes on during the game.
I suppose the code and sort of "average" all that out of the data.
Since many teams probably used the Gyro last year, there must be some that have a sense of how useful it is.
(I know that many had remarked that if you use it to calculate position, you can have alot of long-term error because of the missed sample time between iterations of the program loop...integration error)
-Quentin
Live free or die....
Unread 22-01-2002, 17:24
JHBurch JHBurch is offline
#0045 (TechnoKats)
JHBurch is an unknown quantity at this point
RE: Filtering Gyro Input
Quentin,
You are correct that the gyro is very sensitive to noise. When using the gyro last year the Technokats used both mechanical and software filtering. We mounted the gyro on a foam pad that reduced some of the noise, and also used a simple filtering algorithm in the code. Details for both of these are provided in the white paper listed above. Obviously the sensitivity is only in the direction (or plane) you're measuring.
If you're concerned about responses to impacts, I suspect it will max out (i.e. read 0 or 255) with even a fairly slight bump. This can be a good thing since it's not too hard to filter out spikes. If I remember right the gyro maxes out at an angle rate that's equivelant to about 1 robot revolution in 5 seconds, so if you're trying to use it to track your robot's heading you better not turn too fast. :-)
Jeff Burch
TechnoKats #45
Unread 22-01-2002, 17:25
Jordan A.'s Avatar
Jordan A. Jordan A. is offline
#0781 (Kinetic Knights)
Jordan A. is an unknown quantity at this point
Send a message via ICQ to Jordan A.
Also, how sensitive is it? Not to bumps really, but to your position?
New FIRST Word: MEGA-REGIONALs Rich Wong Rumor Mill 28 21-10-2003 15:42
3 letter word restrictions??? Yucky!!! Elgin Clock CD Forum Support 4 15-12-2002 16:19
Goal on side... What's the final word! archiver 2001 4 23-06-2002 22:39
??? Copyrighted Music: The Final Word ??? Ranma 3D Animation and Competition 2 16-03-2002 18:06
Fun Little Word Game Torchin Chit-Chat 14 10-11-2001 11:42
