Go to Post If mentors don't respect the students' desire to learn and take an active role in the construction, they're missing the point of FIRST. If students refuse to accept the knowledge and experience of the mentors, that's not independence - it's arrogance. - DB213parent [more]
Unread 16-03-2016, 17:31
AbsoluteZero AbsoluteZero is offline
FRC #2415
AbsoluteZero is an unknown quantity at this point
Pneumatic Tank Sizes
So my team recently added several new pneumatic systems to our robot and in turn, we need more tanks. Space is limited this year on the robot so we were wondering, is it possible to use several tanks that are shorter that the normal black, Clippard tanks? I've looked through the manual and nothing seems to prohibit the use of smaller tanks but I want to be sure before we put them on the robot.
Thank you so much for the help!
Unread 16-03-2016, 17:38
KMeyers's Avatar
KMeyers KMeyers is offline
AKA: Kevin Meyers
FRC #5109 (Gladiator Robotics)
KMeyers has a spectacular aura aboutKMeyers has a spectacular aura aboutKMeyers has a spectacular aura about
Re: Pneumatic Tank Sizes
Assuming they are rated for at least 120 psi, you can use whatever size tanks you want.(just not the old white clippard tanks)
Unread 16-03-2016, 23:43
MetaEngineer's Avatar
MetaEngineer MetaEngineer is offline
Director of magic smoke
AKA: Barden
FRC #0246
MetaEngineer is an unknown quantity at this point
Clippard sells a variety of tanks besides the plastic ones. Even the smaller metal tanks will be heavier than the plastic ones, so keep an eye on how much weight you are adding if that is a concern.
http://www.clippard.com/products/cylinder-volume-tanks
All those tanks will take a long time to fill, so precharging the system before a match will be important. If you don't need quite as much force from some of your actuators, you can conserve air by reducing the pressure setting on your main regulator or by adding a second regulator set at a lower pressure downstream of the main regulator. This reduces the load on the compressor and may mean you need less storage.
If the regulator(s) cannot pass air quickly enough for some of your actuators, adding a small tank after the regulator(s) provides a reserve of working pressure air that can be delivered very quickly.
Unread 23-03-2016, 08:02
You might want to think "electrically" when adding your tanks. Tubing and fittings act as resistors so simply putting more tanks in series may not improve your pneumatic response.
Unread 23-03-2016, 08:16
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
As long as the tank is rated for 120 psi, and isn't the white Clippard tank, any size tank is allowed. We use this tank on our robot this year, and it's been very nice.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 23-03-2016, 08:24
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Absolutely, I've been looking at using these since they have their ratings marked right on them.
Unread 23-03-2016, 12:41
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Make sure you leave the filters in place. Pneumatics must remain pristine from the manufacturer.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
