Go to Post Like his father, John V-Neun will soon have the advantage of his head resembling a game object. - Eric O [more]
Unread 17-03-2016, 01:11
lethc's Avatar
lethc lethc is offline
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
lethc will become famous soon enough
Re: Turn-to-angle PID tuning
From my experience adding a 'minimum' output to your PID loop is by far the quickest, most painless solution. Our drivetrain has a large amount of friction and adding the minimum made it much more responsive and quicker to tune. It exponentially shortened PID tuning times for my team.
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
Unread 17-03-2016, 01:28
See this thread http://www.chiefdelphi.com/forums/sh...d.php?t=145404
Unread 17-03-2016, 01:31
Oblarg Oblarg is offline
AKA: Eli Barnett
Originally Posted by Tom Bottiglieri View Post
Originally Posted by Jared Russel
This is a constant source of annoyance for doing precise turning with high-friction wheels. Some solutions that have worked for us in the past:
1) Figure out what the minimum required output is to get the robot to turn at all. If the PID output is less than this magnitude, output this magnitude (with the same sign as the PID output).
2) Instead of using your heading PID loop to generate PWM commands directly, use it to generate velocity commands that a second PID loop on each side of the drive will attempt to follow. Note that good velocity control at low speeds requires a really fast control loop and accurate velocity measurement. The CAN Talon SRX and CTRE Mag Encoder have impressed us in this regard.
3) Motion profiling can help (a bit) to ensure that the robot smoothly glides to its final heading, but this method works best in conjunction with 1 and/or 2.
Well, this is quite nicely consistent with our observations. We're already implementing suggestion 2) but we're handling PID in the 50hz main loop which is probably unable to handle the low speeds adequately. Minimum output it is!
Thanks for the help, both (or all three?) of you.
If anyone has input for a good P value for the "drive straight" loop, though, it'd still be greatly appreciated.
"The breakfast of champions!"
