Go to Post I will never forget Dean's opening lines: "I want you to know that I am here under protest. I believe that everything you are doing here is repugnant and ethically wrong. And now I am going to tell you why..." And for the next 35 minutes, that is exactly what he did. - dlavery [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 03-03-2016, 22:33
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
ArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to all
Help needed with algorithm
Hello.
I am finally got to seriously play with Arduino boards and want to control bank of 24 LEDs. Idea at the moment is to create a single wave of light. I thought I was on the right track, but results are not what I expected.
Here is my code snippet:
  float in, out;
  for (in = 0; in < pi * 2; in = in + pi/500)
    for (int i = 0; i <= 23; i = i + 1)
      if (in > pi * 2 * i / 24 )
        out = ((cos((in - pi) - (i*(pi*2)/24))+1)/2) *4095;
        tlc.setPWM(i, out);
        tlc.write();
There must be a simple solution for this and it just escapes me.
Any help is appreciated
2017 FTC 11722 (Coach)
2016 FTC 10544 (Coach) Canadian Championship Finalist, Rockwell Collins Innovate Award.
2014 FRC 5064 (Mentor)
Unread 03-03-2016, 22:48
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Help needed with algorithm
I'm not following what you're trying to do, or how the LEDs are arranged.
Are the LEDs arrayed in a line, a circle, or something else? Which LEDs do you expect to be lit at any given phase of the circle?
One thing that is unusual looking is the if block. Note that the LEDs for which
in <= pi * 2 * i / 24
Will be unchanged from whatever their previous state was. For most purposes of this type, you would have an else block to turn lights off or some such.
Edit: Also, did you really mean to have 24,000 calls to the cos() function per wave? That could take a while on an arduino.
Unread 03-03-2016, 23:43
Enginerd
FTC #11722
I am trying to make a single wave like this http://people.sinclair.edu/nickreede...iftMinus90.gif spans over 4 LEDs
this was intended to have values assigned to LEDs only after RAD passes step value
My brain so hurts right now thinking about it, I may put it aside for a bit in favour of linear values
Unread 04-03-2016, 06:05
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Print out the values of i, and out and see if they are what you expect.
Make sure the value being passed to the COS function is in the right form (degrees, radians, gradian).
LED's are typically on/off. Passing continuous PWM values could have unexpected results for values not near full on or full off.
Unread 04-03-2016, 07:59
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Do you have an array that is 24 LEDs tall by some other number of LEDs wide? If so, how wide? Your current algorithm seems to be directed at filling an array 24 x 1000 LEDs. If your array is shorter (or longer) than this, you will need to change the increment of the outer loop. (Change the 500 to half of your array length.) If that doesn't do it, I can't help much more without seeing the details of the libraries and possibly hardware (LED array) you're using; a link to a page about the array would probably be enough of a lead.
Unread 04-03-2016, 12:53
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
If you have a single long strip of 24 individually controllable LED lights (such as this), you are probably asking about a KITT light, or a Battlestar Glactica Cylon light, or (more generically) a Larson scanner, who created the effect, you can do a search for the names and get plenty of solutions. Adafruit has a nice project that explains it. Your LEDs might have different calls to address the bulbs, but the code concept is the same. This is what it sounds like you're trying to do.
If, instead, you have an array of the LEDs, to make a sine wave, that's different.
If this is your first time working with LED strips, look for examples on how to use that particular type and try them out, making changes to the examples to see how the code operates.
Sometimes (most of the time) if your code "doesn't work" it is just missing one important bit, or your hardware isn't wired correctly. Code examples that work eliminates a lot of errors.
Unread 04-03-2016, 14:05
Enginerd
FTC #11722
If, instead, you have an array of the LEDs, to make a sine wave, that's different. KITT lights where on my to-do list, I just didn't remember what it was called.
Thank you all for helping me.
Roger, your first half of your post is most helpful. I will poke at them tonight when I get home.
What I have is Adafruit 24-Channel 12-bit PWM LED Driver - SPI Interface - TLC5947 with individual 24 simple LEDs connected.
Sin or Cos wave is not to display a wave on LED matrix, but rather control brightness of the LEDs of a row of LEDs and that where PWM controller interface come in play.
I don't have NeoPixel strip yet. I will order NeoPixel or DotStar when I get my tax refund . Perhaps it is easier for what i am trying to do. We'll see.
Unread 04-03-2016, 14:32
FRC #1153
Rookie Year: 1900
The older LED Strips work just as well, by the by. It's mostly density and how they are programmed. The one I pointed out just happened to be the high end $. The lower end cost ones work well with the Arduino family without added boards. With 24 you can get by with just power off the Arduino.
Just be extremely careful not to feed the LEDs with more volts than specified!
Unread 04-03-2016, 14:39
Enginerd
FTC #11722
I did ordered few of these
http://www.ebay.com/itm/371518334189
Hopefully they are programmed same way as Adafrut strips
Unread 04-03-2016, 20:10
FRC #1153
Rookie Year: 1900
Those may be more work than I could take. You have to wire them up yourself, but you do get to put them in your own pattern, even arrays or more. (Just have to wire them serially.)
Searching around for ws2812b I found Sparkfun's tutorial on their own WS2812 and their Breakout board, with of course code. Again, start with their libraries and their examples, and get the feel for the method before trying your own.
Unread 05-03-2016, 04:59
FRC #1153
Rookie Year: 1900
In regards to the code
  float in, out;
        tlc.setPWM(i, out);
        tlc.write();
I don't think this does what you think it does.
Running it thru a spreadsheet, that if (in > pi * 2 * i / 24 ) only is true for 1 of the 24 i loops, so re-sets the LED 1/24th of the time. Good practice is setting the LED each loop, even if it is off, because the LED will keep the previous number until changed.
When it does set the LED, out is in a range from zero to the low 4000s. If these LEDs are typical, the range is zero (off) to 255 (full on). Plus if they are color, you have to set each Red-Green-Blue to a level -- typically something like
tlc.setPWM( i, color( outR,outG,outB ) );
Find the command in the examples; I'm just guessing what it is.
Unread 09-03-2016, 23:57
Enginerd
FTC #11722
Thank you Roger, that is useful info I didn't have. I hope LEDs will arrive soon for me to try them.
I am getting tired of TLC5947, as it continues to produce some artifacts that are not in the code. I tried 3 simple loops, 1st 100%, 2nd 50% and 3rd 0% brightness. It all works as expected but at the end of second loop all LEDs blink.
Unread 17-03-2016, 01:42
Enginerd
FTC #11722
I am still waiting for ws2812b LEDs, but after a bit of a break and then practicing on direct PWM pins, I finally cleaned up logic enough for it to do almost what I want. Here is what I got so far:
PHP Code:
void loop() {
float inouttemp;
int i;
  for (
in = -piin pi 24in in pi 50)
    for (
0<= 231)
temp pi LED_Group i;
      if (
in >= -pi temp && in <= pi temp )
out cos(in temp) * 2048 2047;
tlc.setPWM(iout);
tlc.write();
LED_Group is for controlling how many LED to include in a wave
