Go to Post wood is the original carbon fibre! - dtengineering [more]
Unread 17-03-2016, 10:34
SerpentEagle's Avatar
SerpentEagle SerpentEagle is offline
AKA: Shashank Rajesh
FRC #3641 (The Flying Toasters)
Team Role: CAD
Rookie Year: 2015
SerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to behold
Re: Bumper Indenting
Originally Posted by Kevin Sevcik View Post
That should be fine, yes. There's no rules about not deforming your bumper, just rules about how your bumper must be constructed and attached.
Also, could you just lower the bumper, bumpers, or that particular section of bumper? Making a separate chunk of bumper just for that area just to lower it there would be a bit extreme, but would also be legal. It looks like you might be interfering with the hard part of the bumper, so this might be your only viable option.
Ok cool. We could possibly lower our bumpers, but for worse case scenario I wanted to know if this was legal or not. Thanks.
Unread 17-03-2016, 10:35
Team Role: CAD
Rookie Year: 2015
Thank you everyone for your quick replies.
Unread 17-03-2016, 10:38
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Lowering your bumpers is an option provided they still are within the bumper zone as defined by the rules
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 17-03-2016, 12:13
mjc49's Avatar
mjc49 mjc49 is offline
Coach - Team 3042
AKA: Mike
FRC #3042 (Cobalt Catalyst)
mjc49 is an unknown quantity at this point
Correct. They must be at least 4" off the ground and no higher that 12". If you are able to lower the bumper and still have a ground clearance of 4" you should be fine.
(2013-Current) Coach-Team 3042 Cobalt Catalyst, MN North Star Regional Winners (2014 w/2177 & 4778, 2016 w/2175 & 3130)
2017 - LRI: MN North Star Regional
Unread 17-03-2016, 12:19
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
As long as by "lower our bumpers" you mean in a permanent, non-articulating way. Have you read the rules? Section 4.7 is all about bumpers. R23 specifies non-articulating.
Good luck!
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 17-03-2016, 14:38
Team Role: CAD
Rookie Year: 2015
Good luck!
Yes, in a permanent way. I never said anything about articulating bumpers.
