Go to Post Welcome to FIRST, the place where you can be competitive in a team. Here people can learn more in one year of FIRST than in four years of high school. - dude__hi [more]
Unread 17-03-2016, 11:48
Legator91's Avatar
Legator91 Legator91 is offline
AKA: Ryan Legato
FRC #0067 (HOT Team)
Legator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud of
Send a message via AIM to Legator91
Re: 2016 HOTBOT
Originally Posted by Adam Freeman View Post
Mike / Ryan,
I assume there will be no tech notes posted (since I'm not there to make one ), but can you walk through the specifics of the design?
There looks to be a bike cable in there somewhere, not sure what crazy idea that is used for....
I really haven't talked to Jim in-depth about the design, so I'd love to know more about it and how you guys came up with it.
-Adam
Sure. The bike cable is used to actuate two bike disc brakes. We needed a way to ensure the robot would hang with the base parallel to the floor. We had several ideas, but then one of the mentors said "hey what about a disc brake". The brakes are mounted to the output shafts of the arm gear boxes. They are actuated by a pneumatic cylinder.
Mike already explained the shooter. It was really "cool", but as he said we had consistency issues with speed. We worked on improving gear mesh, wear, etc but no luck. So once we reveal the new design we can talk about it more.
Ball intake uses one 2 inch roller to bring the ball into the robot. We then have two conveyors that direct the ball towards center. One being powered, and the other driven by a cross over loop.
Other then that its just the usual HOTBOT chasis modified to fit the design for the game. We do use pneumatic wheels to aid in crossing defenses. We discussed tank treads, but after some research from past seasons we decided pneumatic wheels were better. They also were easier to package. We also use pneumatic shifting. So I guess we are starting to accept pneumatics into the design, when we never used to use them.
Full disclosure: Mike, Eric, and Jim were the leads this year on design. I was not able to commit as much time as I would have liked this season. I did help bounce ideas around, and aid in design and build where I could. Mike and Jim could go way more into detail.
Michigan Tech: 2010 - 2014
University of Michigan: 2015 - Present
Mentor (FRC 67): 2015 - Present
Mentor (FRC 3771, 4363): 2011 - 2012
Student (FRC 67): 2007 - 2010
2010 World Champs (294, 67, 177)
2009 World Champs (111, 67, 971)
Unread 17-03-2016, 12:45
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Re: 2016 HOTBOT
Drive train is 2 CIM ball shifters 8wd with 8" AM pneumatic wheels, running 25 chain this year. Pneumatic system was added the Sunday before ship after concerns about our door lock actuator motor shifting robustness. We weighed about 100 lbs at this point and decided to bite the bullet. We use for shifting and arm brake actuation. Might be using a cylinder for portcullis actuation at Howell - Jim's working on something for this.
The arm has a 49:1 versa planetary into a double reduction gearbox 9.52:1. This was used over another planetary stage for durability concerns with this game. Then a chain reduction of 100:22. Saturday before ship we broke the teeth off the small gear in the 9.52:1 gearbox going over the rough terrain. Everything was replaced with steel gears before bag night and we started design on the brakes and a gas strut system. The rotor is on the gearbox output shaft before the chain reduction mostly because it packaged well, but it also gave an additional mechanical advantage to stopping the chassis. The main concern with that is chain strength - at Waterford we broke the arm chain on one side, and not just on a master link. We'll see how it plays out, but chain is easier to replace than gearboxes and we have some redundancy.
Hang is powered by 2 x 775 pros into 3:1 planetaries belt driving lead screws in both arm tubes. We had an issue with driving the lead screws out the end at Waterford, but that was mostly code and is resolved now.
Intake is a 10:1 BAG motor with a 30:24 reduction in belt. Same motor powers the centering belts through a bevel gear.
Overall weight right now is 107 lbs. The shooter change may eat up 0.5 lb or so, so we have some room to play.
Main focus for Howell improvements will be high goal and lots of practice time.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
