Go to Post if we can't rely on experience and the human mind from time to time, then we're in trouble, aren't we? - Adam McLeod [more]
Unread 17-03-2016, 01:55
Boltman Boltman is online now
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Rethinking the Low bar
I think everyone should build a smaller bot at some point. We learned a lot in how to efficiently package multiple systems and electronics. It was definitely a learning experience and proved very effective going over obstacles without tipping . I am of the opinion a low bot can do anything as well as larger bots minus better defense. Most of the past world champion captains tended to be low to the ground bots. I think we may continue to go smaller and more compact in the future.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star #21 | Galileo Division #91
Unread 17-03-2016, 07:28
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Originally Posted by themccannman View Post
The only thing that determines when an object tips over is when it's COM passes outside of it's footprint projected in the direction of gravity (downward).
That's only true in the static case. It's possible to save a situation that would statically be a tip by accelerating or decelerating, which is the equivalent of pushing the CoM one way or another. You can also cause a tip in the same fashion. A heavier robot with more rotational inertia is going to tip less than a lighter one because your motors stay there same. I guarantee you I could build a chassis that flips due to its own wheel force, and fix it by adding weight without changing CoM.
Unread 17-03-2016, 08:36
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Yes but I believe the static case for that occurring and the dynamic case are different. When stationary we could pull our robot back to quite a degree without it tipping over but when we attempted to cross defenses the robot turned into a pendulum and it tipped. Adding ankle weights at the four corners prevented it from happening again. Our COM was already low so it wasn't just the COM that needed to be adjusted to fix the tipping issue.
Unread 17-03-2016, 09:48
mateoland mateoland is offline
FRC #0399
mateoland is an unknown quantity at this point
The problem I saw with the higher robots was not necessarily that they would tip, but that so much time was spent waiting for the teetering to dampen out before being able to drive again. It plagued a couple of teams in Los Angeles. If they hadn't waited a moment to let the back and forth movement settle, they would have most likely driven "under themselves" and tipped backwards. Precious seconds lost multiple times in a match.
Unread 17-03-2016, 11:31
Legator91's Avatar
Legator91 Legator91 is offline
AKA: Ryan Legato
FRC #0067 (HOT Team)
Legator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud ofLegator91 has much to be proud of
Send a message via AIM to Legator91
Yes. The low bar is one of the easiest ways to get through the defenses. By designing for it you also build a robot with a low CG. This then makes going over the other obsticles without tipping over much easier. Its worked well for us so far. It did take some extra time to design, but it was worth it.
Michigan Tech: 2010 - 2014
University of Michigan: 2015 - Present
Mentor (FRC 67): 2015 - Present
Mentor (FRC 3771, 4363): 2011 - 2012
Student (FRC 67): 2007 - 2010
2010 World Champs (294, 67, 177)
2009 World Champs (111, 67, 971)
Unread 17-03-2016, 11:39
Trevor1523's Avatar
Trevor1523 Trevor1523 is offline
Meme Queen
FRC #1523 (MARS / 6685 RPBHSR)
Trevor1523 is an unknown quantity at this point
Right after we watched the reveal video on the 9th we went to 179's field to see what it looked like. When I saw the height of the low bar I looked at one of my team mates and said "There's no way we're fitting under that". I would probably still have the same reaction.
For me, the low bar is an obstacle that I personally knew most teams would design their robot for because "OOOOHHH WE GOTTA DO EVERTHIN'". So we decided not to. I think we would make that decision again. Even with our #tallbot we still had trouble packaging everything into what we built so kudos to all those low bar robots.
EDIT: I've been wanting to say this for a while and I feel like this is an appropriate place to say it:
The low bar is a defence, yes? Yes. So I looked at the problem as would we design our robot to just be able to damage one defence, say the Portcullis. That Portcullis design is essentially your constraint and you can't remove it, you can't work around it. It has to stay there. So we decided to not let 1 defence constrain us when there are 8 other ones that are available to take down. (I think that makes sense)
2015 Orlando Regional Finalists
FRC Team 1523 [2014-xxxx]
FRC Team 6685 [2017]
Unread 17-03-2016, 12:04
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
We would definitely take the low bar approach again. We looked at it from a strategy standpoint from district events through worlds. Add to that the design and engineering challenge of getting everything to fit in a tight package. It's a really good lesson in minimalist design. We opted to not have pneumatics this year to save space, and aren't regretting that decision at all.
We typically are crossing the other defenses in teleop, but we still wanted to be able to handle that one, as we might be paired with 2 robots who couldn't do the low bar. From our week 2 event, there were a few times we had to cross the low bar because an alliance partner wasn't able to complete it for one reason or another.
When we are in tower attack mode, it provides a quick path to go back and forth from the neutral zone and/or secret passage. We used it often (though not always) to make that trip.
Low bar isn't for everyone, but it provides a fun challenge.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 17-03-2016, 12:05
BotDesigner's Avatar
BotDesigner BotDesigner is online now
Design/CAD/Strategy/TeamManagement
AKA: David Gedney
FRC #4418 (Team Impulse)
BotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud of
My team totally ditched the low-bar Saturday after bag and tag. We are using our withholding allowance to build a mechanism for Colorado that I believe should be able to change the way defense is played in this game.
Unread 17-03-2016, 12:33
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #0846
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
Acceleration is a force and therefore would affect the direction of your footprint projection. The footprint is projected in the direction of all forces acting on the robot, I just said gravity because that is always present.
This would prevent the tipping because it would reduce the robot acceleration, and rotational acceleration (which means it would have to undergo lateral acceleration for longer before reaching its tipping point) therefore changing the footprint projection, that's the real reason it wouldn't tip.
As mentioned above, the cases are the same, you just add another vector for robot acceleration.
Very true, the reactionary force when the robot stops makes it like a pendulum, you want to accelerate out of phase with the robot tipping period to not magnify it.
All posts here are purely my own opinion.
2011-2015: 1678
2015-current: 846
Unread 17-03-2016, 13:23
engunneer's Avatar
engunneer engunneer is online now
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Counter argument: our design goal was to be able to breach alone, and we picked low bar instead of c class defenses. It means we I ly have to be capable of 7/9 of the defenses instead of 8/9 which would be needed for a solo breaching #tallbot.
I told my students on day two that the game isn't hard per se, but it is a difficult packaging problem, which is very common in engineering.
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2016)
Unread 17-03-2016, 15:08
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
let's see if you found what I found
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 17-03-2016, 15:20
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
We are a tall robot and to be honest I am still alright with that decision. Our biggest problem isn't the robot wanting to tip over it is that our drivers are afraid of breaking the robot so they keep stopping while going over defenses. This makes us "look" like we will tip. We are using the original AM wheels on our tracks and not so much as a crack (we made hubs to take the abuse).
Unread 17-03-2016, 16:12
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Without a doubt we would still plan to go under the low bar. We have had multiple matches this year where our ability to do the low bar directly added to our RPs earned in a match (in particular our solo breaching when we are the only robot on our alliance).
Self reliance is something I brought up in the old Low Bar threads and I am very happy to report that it was the right choice for us.
Unread 17-03-2016, 16:25
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
If my team had the experience and the skill to make a fast, accurate high goal shooter, than we might have. However, we have a track record of building functional but not exceptional shooters, and this year, we just decided we didn't need to shoot high goals.
I am still happy with our decision as it forced us to embrace CAD more in our design process (something the rest of my team had been dragging their feet about) to get everything to fit under that 14" limit. Also, as long as the improvements to our intake we plan on implementing at the Regional work, we should be able to run low goal cycles very quickly, and crossing the Low Bar is critical to that strategy.
Oh, and we inadvertently built a robot that can climb stairs unassisted. That wouldn't have happened if we had gone tall.
Unread 18-03-2016, 14:03
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is online now
FRC Video Review - Change is Coming
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
We prioritized breaching and bouldering and that included the low bar. I wouldn't change a thing. Our robot is a breaching machine and could do 3 - 4 low goals a match at our first regional. The low bar allowed us to keep our center of gravity insanely low which made us able to zip over defenses with no worries of tipping.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
