Go to Post FIRST is like pizza--you and I might prefer different toppings, but there's no wrong way to do it. - Billfred [more]
Unread 16-03-2016, 23:58
Bernstern Bernstern is offline
FRC #2141 (Spartonics)
Rookie Year: 2015
Bernstern is an unknown quantity at this point
Help with coding CPP and OpenCv
Hello,
I am working with the Jetson Tk1 and Nvidia Toolkit for the FRC stronghold competition. I have spent 8 hours today working on this and have basically given up. Are any teams willing to give up their cpp files for vision on a coprocessor, or willing to help because at this stage anything would be great .
Programmers, a species indigenous to robotics that can convert caffeine into code.
Unread 17-03-2016, 00:07
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: Help with coding CPP and OpenCv
You should use the search functionality of the forum, there's lots of stuff.
http://www.chiefdelphi.com/forums/sh...d.php?t=142173
Unread 17-03-2016, 12:37
ProfessorAlekM ProfessorAlekM is offline
FRC #6190
ProfessorAlekM has a little shameless behaviour in the past
You could try using my blob detection code here: http://einsteiniumstudios.com/make-y...ck-a-ball.html
Despite the fact that it's named 'ball tracking for BeagleBone' it's actually just blob detection on a debian/ubuntu system.
Unread 24-03-2016, 20:00
axton900's Avatar
axton900 axton900 is offline
Programming Co-Captain
FRC #1403 (Cougar Robotics)
Rookie Year: 2015
axton900 has a spectacular aura aboutaxton900 has a spectacular aura aboutaxton900 has a spectacular aura about
Hey there!
If you are looking for some OpenCV CPP code that would be useful, I would recommend taking a look at Team 2053's TowerTracker which is a C++ port of Team 3019's TowerTracker which can be found here: https://github.com/team2053tigertron...016/src/vision
Good luck!
Unread 26-03-2016, 02:47
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Originally Posted by axton900 View Post
Hey there!
Good luck!
Please include complete link? I'd like to look at this.
TIA
Unread 26-03-2016, 07:56
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Here you go
here
We also have code that works on the raspberry pi. I can upload that tonight if you want.
Unread 26-03-2016, 19:13
axton900's Avatar
Rookie Year: 2015
Hey there!
I would be interested in that if you don't mind. Our team is also using a Raspberry Pi and would like to see how you pushed that through.
Thanks!
Unread 27-03-2016, 09:34
jreneew2's Avatar
AKA: Drew Williams
I can grab the file tomorrow. Basically we ssh into the raspberry pi through the robot radio then edit the files via the command line. We use systemctl to run a bash script that sets up the library path and then runs the program at startup of the pi.
Unread 27-03-2016, 09:39
FRC #6190
Making your Co-Processor run it's tracking software at startup seems to be the way to go.
We used a BeagleBone Black for vision on our robot. Apparently the FMS won't let you ssh in when you are connected to it.
I didn't have time to try, but can you ssh in if you change the ssh port to one of the available ports for UDP with the roboRIO?
Unread 27-03-2016, 10:28
jreneew2's Avatar
AKA: Drew Williams
I can try, but I don't think it matters that much because you wouldn't need to ssh in while connected to the FMS. All we need to do is connect to the robot over Ethernet during the field calibration time, and change the RGB threshold values that it sees. This is really fast with grip because you save an image onto the pi at boot up of the pi and download it onto your pc to run grip on it. Then change the values accordingly.
Unread 27-03-2016, 18:37
axton900's Avatar
Rookie Year: 2015
Thanks!
