Go to Post We also have a " big daddy" hand riveter. In my estimation one could have assembled the George Washington bridge with it. - DonRotolo [more]
Unread 16-03-2016, 22:23
voidpigeon voidpigeon is offline
FRC #1515 (MorTorq)
voidpigeon is an unknown quantity at this point
Presenting MorScout - FRC scouting system for iOS, Android, and web
MorTorq Team 1515 is proud to present our newest iteration of MorScout!
Web: http://www.scout.morteam.com/
Android: https://play.google.com/store/apps/d...m1515.morscout
iOS: In Apple Store approval process - coming soon
What is MorScout?
MorScout is a user-friendly FRC scouting application available on iOS, Android, and web clients. It allows teams to create a custom scouting form, record match data, and compile information to improve match performance and assist in alliance selection. We’ve completely revamped the system from last year by creating a central, easy-to-configure server, improving the UI, and adding a ton of new features.
Why use MorScout?
Custom scouting forms are the key new feature in this year’s version of MorScout. Both match and pit forms are completely customizable so that you can record all of the information that you need and none that you don’t. To save some time, we’ve already made a default form for Stronghold, but you’re free to add or remove any data points you’d like. We’re still working on some features, like easy data point reordering and updating, but we will push that out as soon as possible.
We’ve integrated MorScout with MorTeam, our team management system, creating one network for all of your FRC needs. However, you do not need to use MorTeam if you don’t want to. MorScout streamlines user assignments as individual scouters can be assigned matches and corresponding teams through the application, eliminating the need to keep track of who scouts which team. Scouting data can either be retained privately in your team or shared publicly to help teams who don’t have the ability to collect detailed match or pit data. You can also view the data of any other teams that are kind enough to make their data public.
“OurScout is MorScout than YourScout”
Unread 17-03-2016, 09:15
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Re: Presenting MorScout - FRC scouting system for iOS, Android, and web
This looks awesome, but whenever I try to do a pit scout or a match scout, and try to submit it, it brings up a toast message that reads "Error submitting report. Make sure you have filled out every item." I filled out all of the necessary items, but it still won't let me submit.
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 17-03-2016, 10:51
rich635 rich635 is offline
FRC #1515 (MorTorq)
rich635 will become famous soon enough
This issue normally occurs if you have radio buttons in the scout form and it requires one to be selected before submitting the report. We'll likely consider changing this feature in the future.
Unread 17-03-2016, 12:44
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is offline
Dancing Drive Coach
FRC #4967 (That ONE Team)
Jarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to all
This is awesome guys! I really want to dive in and see if this is a viable option for our team moving forward this season. Is there any ability to export the data so it can be viewed and manipulated?
Unread 17-03-2016, 18:30
Farbod909 Farbod909 is offline
FRC #1515
Farbod909 is an unknown quantity at this point
Hi, you can look at all the matches for a specific team in a regional using the web application. Unfortunately due to screen size constraints this feature would not be feasible on the iOS and android clients. In the near future we will try to make it possible for teams to export scouted data in an excel file or something similar.
Web app exclusive features include:
  • Form creation
  • All matches overview for a team
  • Assigning matches to scouters
  • Viewing other users' profiles (user search)
  • More detailed matches list
  • Viewing team awards and statistics
Unread 17-03-2016, 19:39
EthanJF123 EthanJF123 is offline
FRC #2614
EthanJF123 is an unknown quantity at this point
I think this is a great idea. Is this something that requires a constant internet connection? I know with other scouting tools online, you have to be on the internet for them to work.
Unread 17-03-2016, 23:21
FRC #1515
The iOS and android clients cache data so it is completely functional when offline. However, some features such as viewing previously scouted data is not available as it would be unpractical to cache such large amounts of data. If you submit a report offline, it will save it locally and send it to the server as soon as an Internet connection is established. We are currently working on creating an offline desktop app as well.
Unread 19-03-2016, 20:14
FRC #1515 (MorTorq)
Whoops, turns out we forgot to post Android screenshots for those interested.
We'd also love to hear some feedback from anyone who used/is using it at a regional. Anything from bug reports to suggestions to simply knowing how you're using it so we can focus further development. Thanks to everyone using it!
Unread 19-03-2016, 22:26
Cabey4 Cabey4 is offline
Vision/Scouting/Strategy/Too much
AKA: Tom Schwarz
Rookie Year: 2015
Cabey4 is on a distinguished road
Hi
Would it be possible to have it export data as a csv?
It would help to allow me do extra analysis.
Do you have any idea on when the computer app would be finished?
This looks amazing, and I would love to use it, but I am worried about needing an internet connection (especially as an Australian team, trying to scout at Champs would become very expensive).
Also, how are you dealing with the chance of the website going down? Because that would be horrible if it meant you couldn't access your scouting data/Scout. Would you ever have to take it down for maintenance?
Sorry for asking so many questions, but it looks amazing and something that I am definitely considering.
Unread 19-03-2016, 22:39
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
So what do the background colors mean on the teams on the all matches page?
We are very likely going to use this to scout Midwest. (If anyone wants to help us scout please do!)
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 20-03-2016, 21:24
FRC #1515
Originally Posted by Cabey4 View Post
Hi
We are currently working on exporting data as csv and it will be available very soon! The same applies for the offline desktop app. However, in the meantime you can use the iOS app (available on Tuesday or Wednesday) and the android app (available now) to scout offline. The mobile apps save data locally and sync when an internet connection is established.
As for the website going down, we use a module called "forever" that ensures that our servers will be always online unless there is an issue with Amazon's servers (which is very unlikely). We might have to take the servers down for maintenance, but if we do, it will be very brief and we will try to do it as little as possible, if ever. In addition, if you're really worried about something happening, you can periodically export the data as csv (which is coming very soon, as i mentioned).
Thank you!
Unread 21-03-2016, 04:31
FRC #1515 (MorTorq)
  • Orange - your own team
  • Red - a team that is on an opposing alliance in the future
  • Green - a team that is on your alliance in the future
  • Purple - meets the conditions of both red and green
These are intended to highlight the teams that are most important to scout.
Unread 21-03-2016, 12:03
FRC #1515
Good news everyone!
Apple has approved MorScout for distribution on the iOS app store. It is now available for download on all iOS devices such as iPhone, iPad, etc.
Here is a link: https://itunes.apple.com/us/app/mors...1171?ls=1&mt=8
Unread 22-03-2016, 18:12
FRC #1515
This feature is now available under settings. Good luck and thanks for trying MorScout!
Unread 23-03-2016, 07:14
GarrettF2395's Avatar
GarrettF2395 GarrettF2395 is offline
AKA: Sierra 117
FRC #2395
Team Role: RoboCoach
GarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of light
Send a message via Yahoo to GarrettF2395
Is there a way for the admin to change the team's unique code?
https://twitter.com/TeamNinjaMunkee
FRC 2395: Team captain 2008-2009, Design mentor 2010-2011, Lead design and strategy mentor 2012-Present
