Go to Post FIRST is, of course, a grand social experiment in American culture - jonathan lall [more]
Unread 17-03-2016, 20:44
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Where are you shooting from and why?
Our team is currently debating shooting positions and I was wondering what other teams have to say about the matter.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 17-03-2016, 20:48
Crazyaimer Crazyaimer is offline
AKA: John Reitz
FRC #2502 (Talon Robotics)
Crazyaimer has much to be proud ofCrazyaimer has much to be proud ofCrazyaimer has much to be proud ofCrazyaimer has much to be proud ofCrazyaimer has much to be proud ofCrazyaimer has much to be proud ofCrazyaimer has much to be proud ofCrazyaimer has much to be proud ofCrazyaimer has much to be proud of
Re: Where are you shooting from and why?
Our team is shooting from the batter to get very high accuracy from a point that is hard to defend. Always gotta go for the hard stop shooting location.
Unread 17-03-2016, 20:49
Rivet Man Rivet Man is offline
AKA: 97525A425
no team (Better than Bolts)
Rivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond reputeRivet Man has a reputation beyond repute
Hi IronicDeadBird ,
When you say your team is debating shooting positions, could you explain why?
I think wherever your robot has the highest shooting percentage should be where you shoot from unless under defense. Also keep in mind that if it takes really long to line up a shot you should go to a faster/better place!
It's like a quarterback in the pocket, the line can only give him so much time and sometimes he's just gotta throw the 6 route!
Glad to see inquiring minds, keep up the good work and I'm sure you lock your position in.
Best Regards,
RM
Unread 17-03-2016, 20:50
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
We shoot from the outerworks with the trajectory at greater than 54" when it leaves the robot space.
Hard to pass up untouchable and unblockable and close to where the balls are picked up.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 17-03-2016, 20:54
Jcarbon Jcarbon is offline
FRC #3322 (Eagle Imperium)
Jcarbon has a spectacular aura aboutJcarbon has a spectacular aura about
We shoot from the outerworks. The main reason is that it removes a lot of possibility of defense. We can't be bumped out of position while lining up for a shot, and we can't be prevented from getting to our shooting position because we can cross directly to it. That being said, we're still working increasing accuracy from that distance.
Unread 17-03-2016, 20:56
Originally Posted by Rivet Man View Post
Hi IronicDeadBird ,
RM
In all honesty just looking for feedback and wanting to pick other teams brains for the approach to thinking.
I'd agree with untouchable but unblockable is up to debate depending upon not just your exit height but where it exits along your robot.
Unread 17-03-2016, 21:03
What issues are you running into with accuracy and how are you dealing with it?
Unread 17-03-2016, 21:05
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Right, the ball exits the robot perimeter at above 54 inches. So I'm not sure how another robot would block that.
Unread 17-03-2016, 21:06
Oh above, my bad misread that if you exit at 54 inches at the front of the robot you can lean into their frame perimeter.
Unread 17-03-2016, 21:35
The main issue is that our drivers never got time to practice lining up on the field. We're making sure they get plenty of practice before our second district. We also are trying to get vision targeting working, but I'm not sure that's going to happen.
Unread 18-03-2016, 07:46
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Both. At our first district - batter only while we worked out some bugs. Plus, we knew defense is always light early in the system.
Later.... outer works. We have the distance and are working on consistency. If you are still debating where you are shooting from, I HIGHLY recommend shooting with a ball that's been used a ton and then a ball that is brand new. You'll find a substantial difference between the two.
Unread 18-03-2016, 08:37
Data Nerd
FRC #0079
We will?
Outer works shot. Camera assisted. Pneumatic catapult on an arm. Also unblockable.
Unread 18-03-2016, 08:42
lethc's Avatar
lethc lethc is offline
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
lethc will become famous soon enough
We're using a linear punch from outerworks range. Our shot is fairly accurate and we drew lots of fouls at GKC when we were contacted while in the outerworks.
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
Unread 18-03-2016, 09:22
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is online now
"Cool" Squad
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Originally we were shooting from the corner (spy box area), but eventually we moved to shooting from just under the low bar. It is quick to line up and very accurate, so it is very easy to take down the tower without defense.
We can move to the corner or batter to low or high goal if we need to due to defense or mechanical failures, however.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 18-03-2016, 09:46
b1nary's Avatar
b1nary b1nary is offline
wasting my time, one line at a time
AKA: Josie
FRC #4329 (Roboteers)
b1nary is an unknown quantity at this point
our robot, trogdor, can shoot high or low. when we go for low, we line ourselves directly up on the side of the tower and hug it. we've had extremely good accuracy with low goals, and when shooting high goals, we place ourself 13-14" from the high goal, a little distant from the defense we just crossed. my distance estimate may be off by quite a bit, however. sometimes we place ourselves directly on the skirt of the tower in front and shoot high.
here's a video: https://youtube.com/watch?v=aJFSEiNU3DA
