Go to Post You mean to tell me there's a weight limit this year?!?!?!!? - Carlo [more]
Unread 18-03-2016, 08:42
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Could epoxy a 1/4" shaft into the hole in the shaft and the use a piece of 1/4" id hose to attach the the encoder to the drive.
Unread 18-03-2016, 09:03
Sohaib's Avatar
Sohaib Sohaib is offline
AKA: Sohaib Nadeem
FRC #5036 (The Robo Devils)
Sohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of light
Re: US Digital Shaft Encoder and VersaChassis Hex Shaft
It'd be a lot easier if you told us what resources your team has access to. From the looks of it, it doesn't seem you have a lathe. Would you happen to have a 3D printer?
2014 Season:
- Drive Coach
- Rookie All-Star Award (GTR-E)
2015 Season:
- Driver
- Deans List Semi-Finalist (GTR-E)
2016 Season:
- Driver
- Alliance Captain (GTR-E)
Unread 18-03-2016, 09:41
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
A little "goop" works too.
it is a little less sticky than hot melt glue, better option to get it apart if needed.
Drill and tap it, put a shoulder bolt in it, with a little locktight, cut the head off it, and use the surgical tube coupling method, with zip ties.
If your mechanism has significant momentum, and the you get encoder bouncing values when you stop due to the surgical tube twisting, change out the surgical tube with 1/4" high pressure fuel line. We needed to do this last year on our elevator. We have used this method for years in the past with surgical tube, last year was the first we saw and issue with bounce, when changing directions, stopping, etc.
The sooner we get behind schedule, the more time we have to catch up.
