Go to Post A 823543:1 reduction should be fine if you ever need to pick up a truck...or a house. - Tim Sharp [more]
Unread 17-03-2016, 21:39
vigneshv vigneshv is offline
FRC #2489
vigneshv is on a distinguished road
US Digital Shaft Encoder and VersaChassis Hex Shaft
We are running a west coast drive with a WCP DS Gearbox, and as suggested, we attempted to use a 1/4" US Digital shaft encoder on an output VersaChassis hex shaft. However, the hole on the shaft seems slightly too big for the encoder, as the encoder shaft slides in and out of the hole in the hex shaft very easily. There doesn't seem to be enough friction to move the encoder shaft along with the turns of the hex shaft. What is the correct way to mount these encoders to those hex shafts?
Unread 17-03-2016, 21:44
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: US Digital Shaft Encoder and VersaChassis Hex Shaft
We turn down the end of our hex shaft to 1/4'' and link the two with surgical tubing and zipties (which work much better and are more robust than any other sort of connection we've tried).
"The breakfast of champions!"
Unread 17-03-2016, 21:48
FRC #2489
What do you mean by turn down the end of your hex shaft?
Unread 17-03-2016, 21:51
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
They used a lathe to reduce the diameter of the shaft.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 17-03-2016, 21:54
AKA: Eli Barnett
To "turn" something in this context means to machine it on a lathe.
If your team doesn't have a lathe, I strongly suggest you invest in one. Even a cheap small hobby lathe (that's what we use) can do wonders.
Unread 17-03-2016, 21:57
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Cut a slot in the shaft. Insert the encoder in the oversized hole. Put a shaft collar around it to make the slotted hole compress down on the shaft of the encoder.
Hugh
Unread 17-03-2016, 22:07
FRC #2489
We already have 0.251" hole in the VersaChassis shaft (which WCP said was designed for a 1/4" shaft encoder), but that hole is too big, and there isn't enough friction between the shaft on the encoder and the hole in the VersaChassis shaft to make the encoder shaft turn with the axle.
Unread 17-03-2016, 22:21
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
We've reamed some of our own shafts and they've came out a little big, we just put some hot glue in there and were g2g. You can do other tricks to make the hole in the shaft work.
R.C.
MadTown Robotics Team 1323
Unread 17-03-2016, 22:31
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
A few other options.
We have been using Ruland flexible couplings with the 1/2" shaft on one end and 1/4" shaft on the other.
You could drill and tap a hole for a #10 set screw and then use a set screw to hold the 1/4" shaft tight.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 17-03-2016, 22:39
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Hot glue works. You can also take a small pocket knife or similar tool and gouge a hefty scratch in the inside of the hole. It should raise a burr just enough to provide a little bit of friction to snugly fit the encoder shaft in there.
You could also try a little piece of scotch double sided tape on the encoder shaft, to take up some of the space.
If you were careful about it, you could probably even use an automatic spring loaded center punch to punch a dimple into the encoder shaft itself, causing it to deform outward a little bit.
I will also note, we typically would not mount encoders of this sort. It's an over-constraint. We would fit them to the shaft, and then just let them float free, placing a zip tie on the cable, just to prevent the body from rotating.
Unread 18-03-2016, 08:42
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Could epoxy a 1/4" shaft into the hole in the shaft and the use a piece of 1/4" id hose to attach the the encoder to the drive.
Unread 18-03-2016, 09:03
Sohaib's Avatar
Sohaib Sohaib is offline
AKA: Sohaib Nadeem
FRC #5036 (The Robo Devils)
Sohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of light
It'd be a lot easier if you told us what resources your team has access to. From the looks of it, it doesn't seem you have a lathe. Would you happen to have a 3D printer?
2014 Season:
- Drive Coach
- Rookie All-Star Award (GTR-E)
2015 Season:
- Driver
- Deans List Semi-Finalist (GTR-E)
2016 Season:
- Driver
- Alliance Captain (GTR-E)
Unread 18-03-2016, 09:41
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
A little "goop" works too.
it is a little less sticky than hot melt glue, better option to get it apart if needed.
Drill and tap it, put a shoulder bolt in it, with a little locktight, cut the head off it, and use the surgical tube coupling method, with zip ties.
If your mechanism has significant momentum, and the you get encoder bouncing values when you stop due to the surgical tube twisting, change out the surgical tube with 1/4" high pressure fuel line. We needed to do this last year on our elevator. We have used this method for years in the past with surgical tube, last year was the first we saw and issue with bounce, when changing directions, stopping, etc.
The sooner we get behind schedule, the more time we have to catch up.
Unread 18-03-2016, 10:42
Chris is me's Avatar
AKA: Pinecone
Just wrap the encoder shaft in a little painters tape or scotch tape until it's a press fit. Single side is fine, you're not trying to fasten anything just increasing the OD until it goes in smooth. There's basically no torque transmitted to worry about so this is totally fine. Don't worry about doing anything more robust than that.
Unread 18-03-2016, 11:50
CLAMPS CLAMPS is offline
Junior Member
Team Role: RoboCoach
CLAMPS is an unknown quantity at this point
I suggest you use a set of clamps.
