Hi All,
We're coding in Java and started experiencing problems with the robot becoming disabled after a random interval. Checking the logs from the dashboard we saw that we were getting a message. Checking the message we found that the JVM was crashing when getting an image using the WPILib native libraries... Code:
# If you would like to submit a bug report, please visit: # http://bugreport.sun.com/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. # Stack: [0xb68e1000,0xb6931000], sp=0xb692f590, free space=313k Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code) C [libnivissvc.so.13+0x258f2c] ProfilerPushLabeledTimer+0x53980 [error occurred during error reporting (printing native stack), id 0xb] Java frames: (J=compiled Java code, j=interpreted, Vv=VM code) J 361 com.ni.vision.NIVision._Priv_ReadJPEGString_C(JJI)V (0 bytes) @ 0xb4815038 [0xb4814fe0+0x58] J 357 C1 edu.wpi.first.wpilibj.vision.AxisCamera.getImage(Lcom/ni/vision/NIVision$Image;)Z (47 bytes) @ 0xb4813b88 [0xb48138f0+0x298] J 326 C1 org.usfirst.frc3932.Robot.runCamera()V (42 bytes) @ 0xb480bac8 [0xb480ba90+0x38] J 324 C1 org.usfirst.frc3932.Robot.teleopPeriodic()V (15 bytes) @ 0xb480b3b0 [0xb480b180+0x230] j edu.wpi.first.wpilibj.IterativeRobot.startCompetition()V+240 j edu.wpi.first.wpilibj.RobotBase.main([Ljava/lang/String;)V+322 v ~StubRoutines::call_stub --------------- P R O C E S S --------------- Java Threads: ( => current thread ) 0xb67a7400 JavaThread "CameraServer Send Thread" [_thread_in_native, id=1733, stack(0xab632000,0xab682000)] 0xad9e7800 JavaThread "Timer-1" [_thread_blocked, id=1591, stack(0xab970000,0xab9c0000)] 0xad9e1c00 JavaThread "Thread-4" [_thread_blocked, id=1590, stack(0xab9c0000,0xaba10000)] 0xabb0c400 JavaThread "Thread-3" [_thread_in_native, id=1589, stack(0xaba10000,0xaba60000)] 0xabb0b000 JavaThread "Thread-2" [_thread_blocked, id=1588, stack(0xaba60000,0xabab0000)] 0xabb0a000 JavaThread "Thread-1" [_thread_in_native, id=1587, stack(0xabab0000,0xabb00000)] 0xad9f8800 JavaThread "Timer-0" [_thread_blocked, id=1586, stack(0xabc1f000,0xabc6f000)] 0xad9f0800 JavaThread "NTListener" daemon [_thread_in_native, id=1585, stack(0xabc6f000,0xabcaf000)] 0xad9bf800 JavaThread "FRCDriverStation" [_thread_in_native, id=1582, stack(0xabdc4000,0xabe14000)] 0xb6799400 JavaThread "Service Thread" daemon [_thread_blocked, id=1570, stack(0xada9e000,0xadaee000)] 0xb6796800 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=1569, stack(0xadaee000,0xadb6e000)] 0xb6795000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=1568, stack(0xadf0d000,0xadf5d000)] 0xb6773000 JavaThread "Finalizer" daemon [_thread_blocked, id=1566, stack(0xadfb0000,0xae000000)] 0xb6771800 JavaThread "Reference Handler" daemon [_thread_blocked, id=1565, stack(0xb4603000,0xb4653000)] =>0xb6705800 JavaThread "main" [_thread_in_native, id=1548, stack(0xb68e1000,0xb6931000)] CPU is at around 75% before the crash, drops to about 50, then 50 15 within a second or 2 until the code gets reloaded. I've attached the log file. Anyone we can talk to since the problem is outside our code? It seems to happen after a random interval between 3 and 8 minutes while the robot is enabled, even if sitting idle. This is a chunk of our Robot.java, pardon the duplicated code - it's a work in progress. Calling camera.getImage shouldn't crash the JVM on us. Eating the exception isn't a good idea either, including both to give the picture of what we actually have right now... Code:
public void robotInit() {
RobotMap.init();
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTRUCTORS
driveSystem = new DriveSystem();
platform = new Platform();
camera = new Camera();
cannon = new Cannon();
onBoardCompressor = new OnBoardCompressor();
shooterWheels = new ShooterWheels();
powerDistributionBoard = new PowerDistributionBoard();
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTRUCTORS
// OI must be constructed after subsystems. If the OI creates Commands
//(which it very likely will), subsystems are not guaranteed to be
// constructed yet. Thus, their requires() statements may grab null
// pointers. Bad news. Don't move it.
oi = new OI();
// instantiate the command used for the autonomous period
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=AUTONOMOUS
autonomousCommand = new DriveTenFeetAuto();
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=AUTONOMOUS
image = NIVision.imaqCreateImage(NIVision.ImageType.IMAGE_RGB, 0);
axis13 = initCamera("10.39.32.14");
axis11 = initCamera("10.39.32.11");
axis12 = initCamera("10.39.32.13");
// Let's detect if that third camera's there
try {
axis13.getImage(image);
// Hooray, it worked!
thirdCamera = true;
catch (Exception e){
// Third camera's not there
// axis13 = null;
thirdCamera = false;
SmartDashboard.putString("Camera 3", axis13+"");
currentCamera = axis11;
ahrs = new AHRS(SPI.Port.kMXP);
rangefinder = new LIDAR(I2C.Port.kMXP);
rangefinder.start();
camera.lightOn();
public void teleopPeriodic() {
Scheduler.getInstance().run();
// checkCompressor();
runCamera();
writeLIDAR();
* This function is called periodically during operator control
private void runCamera(){
try {
currentCamera.getImage(image);
CameraServer.getInstance().setImage(image);
} catch (Exception e) {
System.err.println("Failed to get image from camera");
System.err.println(e.getStackTrace());
public static boolean hasCameraThree() {
try {
return true;
return false;
Last edited by adamzg : 03-04-2016 at 10:19 PM. Reason: missed important block of code |
Re: WPILIB Camera Code Crashing JVM
Not sure if this is related or not to your issue, but we had a problem with exhausting memory when grabbing images that would cause the robot code to crash and burn after running for a certain time period.
We found a fix (or work around) by invoking the free() method on the image objects returned after we were done with the image. The following provides an idea of what we did. Code:
// Grab image from USB camera and push out to camera server
// for smart dashboard display
Image frame = NIVision.imaqCreateImage(ImageType.IMAGE_RGB, 0);
usbCamera.getImage(frame);
cameraServer.setImage(frame);
// Program crashes with out of memory issue if we remove this line
frame.free();
Again, not sure if this is related to the problem you are seeing (I didn't see anything in your error messages about running out of memory), but it might be something to try. Good luck. |
Thanks for the advice, certainly worth a try. The WPI lib for imaging is all native alls, not pure java, so anything is possible...
The free didn't help. If we were holding out a resource I'd expect to see the application (robot) start throwing out of memory errors, although it is possible that if the JVM is allocating memory and has been started with enough memory allocated that it's exhausting the OS's available memory it's being killed by the oom killer (beware the oom killer!). I'm not sure if that would create a crash report.
Maybe something in /var/logs could provide a clue? Even if I find it I'm not sure we'll be able to fix it since it's in WPI's native libraries somewhere. Any thoughts on who to contact for support on the WPI lib? |
#7
To provide some clarity, we can see from the stack from the JVM that we're in com.ni.vision.NIVision._Priv_ReadJPEGString in wpi's lib when the jvm crashes...
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code) J 361 com.ni.vision.NIVision._Priv_ReadJPEGString_C(JJI)V (0 bytes) @ 0xb4815038 [0xb4814fe0+0x58] J 357 C1 edu.wpi.first.wpilibj.vision.AxisCamera.getImage(Lcom/ni/vision/NIVision$Image;)Z (47 bytes) @ 0xb4813b88 [0xb48138f0+0x298] J 326 C1 org.usfirst.frc3932.Robot.runCamera()V (42 bytes) @ 0xb480bac8 [0xb480ba90+0x38] J 324 C1 org.usfirst.frc3932.Robot.teleopPeriodic()V (15 bytes) @ 0xb480b3b0 [0xb480b180+0x230] j edu.wpi.first.wpilibj.IterativeRobot.startCompetition()V+240 j edu.wpi.first.wpilibj.RobotBase.main([Ljava/lang/String;)V+322 Code:
public static AxisCamera currentCamera;
try {
#8
Looking at the source for NIVision I think the .free() will work if used in a finally block. When we tried it the first time it didn't end up in a finally block and the image was being used as a member variable.
The NIVision class is calling C libraries that allocate memory outside the JVM so the correct steps we need are (pseudo code):
Will repost when we understand better. |
#9
Still crashing.
Here's the JVM version... Code:
gsmin@roboRIO-3932-FRC:/usr/local/frc/bin# /usr/local/frc/JRE/bin/java -version -XX:+PrintCommandLineFlag java version "1.8.0_06" Java(TM) SE Embedded Runtime Environment (build 1.8.0_06-b23, profile compact2, headless) Java HotSpot(TM) Embedded Client VM (build 25.6-b23, mixed mode) admin@roboRIO-3932-FRC:/usr/local/frc/bin# cd /usr/local/frc/JRE/bin admin@roboRIO-3932-FRC:/usr/local/frc/JRE/bin# ls java keytool rmid rmiregistry admin@roboRIO-3932-FRC:/usr/local/frc/JRE/bin# cd Code:
Mem: 176600K used, 75372K free, 0K shrd, 93K buff, 3067729088K cached CPU: 9% usr 12% sys 0% nic 76% idle 0% io 0% irq 0% sirq Load average: 2.22 2.15 2.30 4/290 8550 |
#10
Here is our latest and cleanest code with all the logic encapsulated in a single class. This still crashes the JVM...
public class CameraConfig {
private AxisCamera camera;
private String URL;
public CameraConfig(String URL){
this.URL = URL;
this.camera = new AxisCamera(this.URL);
camera.writeExposurePriority(50);
public void sendImage() {
Image image = NIVision.imaqCreateImage(NIVision.ImageType.IMAGE_RGB, 0);
try {
camera.getImage(image);
} finally {
image.free();
public boolean exists() {
boolean flag = false;
try {
flag = true;
finally {
image.free();
return flag;
#11
What happens if you make image a class variable? Allocating and deallocating it are expensive.
It also looks like you are using last years JRE. |
#12
We flashed all our roboRIOs this year, what makes you think it's last years Java version? I'll check on our end to make sure the RIOs are all running build 1.8.0_06-b23, I don't think they would work at all if we hadn't flashed them. Can you post a link or provide info. on why you think the JVM version is wrong and where/how we'd get the right one? Thanks for your help! |
#13
(there must be a good reason that wpilib isn't using finalize() to call free() - maybe finalize is unreliable?) Anyway, I have to go with the previously stated recommendation, that you reuse the same image object. NI vision allows you to do that. |
