Go to Post Unsure if I'll get it to work, but that's no reason to not try. - DonRotolo [more]
Unread 18-03-2016, 14:12
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Re: US Digital Shaft Encoder and VersaChassis Hex Shaft
Originally Posted by R.C. View Post
We've reamed some of our own shafts and they've came out a little big, we just put some hot glue in there and were g2g. You can do other tricks to make the hole in the shaft work.
I would like to add a warning about hot glue. Only use it on encoders used for speed sensing, if you need to sense position please use a set screw, press fitting or some other method that assures the shafts is locked down. I realize that the OP has specifically said it is for the drive train and thus we can concluded that these are for speed sensing. That said I personally made the mistake of applying that to a hall-effect pot which has lead to some unpleasant failures this year. I hope that no one ever makes the mistake I did.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 18-03-2016, 14:43
Treadus Treadus is offline
FRC #1987 (Broncobots)
Treadus is an unknown quantity at this point
We have used hot glue to get a good fit in the VersaChassis hex shaft in the past with great results.
This year we hot glued the encoder in the shaft, but ended up breaking one of our encoders (the shaft seized up). Likely due to shock and shifting alignment on the encoder. You know, catching air over defenses and all.
To echo one of the previous suggestions, I would highly recommend using a helical beam coupling to protect the encoder from shock and so you don't have to stress out too much about alignment. Especially for this game. Since we seized up the one encoder, we've moved to using a helical beam coupling and have had no issues.
Unread 18-03-2016, 15:53
Oblarg Oblarg is offline
AKA: Eli Barnett
Surgical tubing and zip ties do this better and far cheaper than a beam coupling. It's one of the best solutions we've shamelessly copied from other teams.
"The breakfast of champions!"
Unread 18-03-2016, 20:02
Sohaib's Avatar
Sohaib Sohaib is offline
AKA: Sohaib Nadeem
FRC #5036 (The Robo Devils)
Sohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of light
Here's a picture of our solution. It's a 3D printed 1/2" hex to 1/4" D-Shaft (the one on the encoder) coupler. We also have the 3D printed mounting brackets. Probably overkill, but we haven't had any issues with the encoder seizing up throughout 12 matches this season, and countless practice hours.
http://i.imgur.com/5u2Yvzb.jpg?1
I can send you the CAD if you want.
(PS. It's the bright orange)
2014 Season:
- Drive Coach
- Rookie All-Star Award (GTR-E)
2015 Season:
- Driver
- Deans List Semi-Finalist (GTR-E)
2016 Season:
- Driver
- Alliance Captain (GTR-E)
