Go to Post It is not your banners that make you nor the trophies that line your walls. It is the willingness to be brave in the face of defeat and compassionate in the winds of victory that create you. - MysterE [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 18-03-2016, 14:38
PneumaticMonkey PneumaticMonkey is offline
None #4269
PneumaticMonkey is an unknown quantity at this point
Power Rules at competition
Hello everyone-- i was wondering about the rules for power outside of the pits. We are trying to run a scouting system of 2 dell laptops, and i need to know if i am allowed to plug in. Thanks.
Unread 18-03-2016, 14:40
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Re: Power Rules at competition
If you can find a free outlet, yes. You most likely won't be able to run something like a 50ft cable from the nearest outlet to where you sit, but most places have a places with outlets somewhere you can occasionally "hijack".
Academic Student (Forever)
Unread 18-03-2016, 15:07
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Outlet convenience outside the pits will depend on the event and venue, but I would not count on it. You may be able to find a place to plugin temporarily outside the stands, but running an extension cord across walkways and stairs to get to where you are seated in the stands could present a serious trip hazard in busy areas.
For our scouting setup, we have used older robot batteries (not good enough for competition) to power laptops, tablets, and for recharging phones. We have a kit built up that includes fuses, an inverter, and 12v DC automotive outlets. I would suggest you look into a similar off-grid setup.
In the PNW district, there is a blanket rule to never plug into any outlets in the gym. If anything is found plugged in (cell phones, etc), they are confiscated until the end of the day. The intent is to make sure no circuits shared with supplying the field power are overloaded. In many cases this is overkill, but some older schools have very limited power to school gyms, and the last thing they want is the field losing power due to a tripped circuit.
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Unread 18-03-2016, 15:26
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
We use old robot batteries and a DC-> AC Inverter. Easily powers 2 laptops. Swap robot batteries every so often (when it hits 12 volts).
Unread 18-03-2016, 15:39
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
The only outlets near the field will probably be either in use, somewhere that using them could pose a trip hazard(under the floorboards in front of the bleachers), or would require an extension. Something like this might work; it's basically a phone power bank for a laptop.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 18-03-2016, 15:45
CalTran's Avatar
Missouri S&T Senior
I think more frequently teams modify car AC-DC adapters to have an Anderson powerpole end where the plug is for power.
Unread 18-03-2016, 15:50
Team Role: Student
Rookie Year: 2016
True. I saw one of those on a robot cart recently. But others already suggested that, so I was trying to give another idea.
Unread 18-03-2016, 16:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Be careful with inverters. Most of them are not true sine wave, and can kill certain types of electronics with switching power supplies, like laptops. If you do use an inverter, I recommend spending a little more to get a true sine wave one. Also, please make sure the DC side of your system is well insulated, fused, and safe.
On the note of power, in Long Beach, I noticed two pits were shared between one 20 Amp circuit. If I recall, we used to get dedicated 20 Amp circuits to each pit, but not this year. I'm glad our neighbors did not have any power tools, or we would have tripped it. Our pit can come pretty close to pulling 20 Amps between 12 batteries charging, two 150W halogen lights, 9 computer monitors, 3 computers, a vacuum, and a copier.
Unread 18-03-2016, 17:17
Team Role: Student
Rookie Year: 2016
Who would expect the Circuit Breakers to have a breaker-friendly pit? I've plugged my MacBook Pro into a modified sine wave inverter and it had no negative effects. I would think that most modern laptops could handle modded sine wave, with adapters that can handle different voltages and such.
Unread 18-03-2016, 17:19
Team Role: Student
Rookie Year: 2016
Pun intended?
Unread 22-03-2016, 07:55
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I wouldn't hesitate to use a switching power supply for a computer. I use one whenever the power goes out, because the vast majority of UPS devices have switching power supplies. If you want to run a stereo or other application where the high harmonics will cause a problem, get a true sine wave inverter.
Unread 22-03-2016, 10:48
Dave Campbell's Avatar
Dave Campbell Dave Campbell is offline
Miami Valley Planning Committee
FRC #0144 (ROCK Robotics)
Dave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant future
Power use outside of the pits is usually venue specific. At the CINTAS Center where the Queen City event happens next week, for example, teams are not allowed to use the outlets in the seating areas. There will be "charging stations" for teams on the mezzanine outside the arena, we see mostly phones, tablets, and laptops there. Also, there is an assigned scouting area with outlets for equal access for all teams in the upper levels of the arena.
Check your local listings for each event venue policy. Be sure to ask the planning committee, event managers or pit admin, don't just assume that you'll have access to power outlets. We are still visitors at the venues.
"Great spirits have always encountered violent opposition from mediocre minds." - Albert Einstein
FRC Team #144 Advisor
Unread 22-03-2016, 11:13
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Actually we are paying customers, at least for the most part. Having said that, you only get what you pay for. Venues have drastically different rules and power availability. Dave has good advice.
Unread 22-03-2016, 11:41
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
In what I believe is a departure from 9 (possibly more) years of past policy, teams at Buckeye this year were prohibited from using the power outlets in the stands. The reason cited was "The Fire Code", although it's not obvious to me why an AJH would prohibit use of fully-NEC-compliant outlets. In previous years many teams used that as a source of power for their scouting efforts.
Unread 22-03-2016, 11:53
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Originally Posted by ayeckley View Post
In what I believe is a departure from 9 (possibly more) years of past policy, teams at Buckeye this year were prohibited from using the power outlets in the stands. The reason cited was "The Fire Code", although it's not obvious to me why an AJH would prohibit use of fully-NEC-compliant outlets.....
Common practice. Site safety concerns to prohibit action that you do not want for other reasons. . How ever one valid safety concern could be tripping hazards of extension cords stretched across passageways or congestion in a passageway.
