Go to Post And when the President of the United States is playing with LEGOs and getting down on the floor to look inside of robots, then I would have to say "Mission Accomplished". - OZ_341 [more]
Unread 18-03-2016, 18:24
zeldathegood zeldathegood is offline
FRC #4277
zeldathegood is an unknown quantity at this point
Camera freeze up during matches
Hi folks -
Last year and at a week zero competition our USB camera image freezes at the beginning of the match and never recovers.
At practice we are fine.
I am concerned this will happen again at our regional.
To set up the USB camera you have to do little code. We had already turned the quality setting to 0.1 I think (sorry I don't have the code in front of me).
Does anyone have any ideas?
Thanks so much for your help in advance.
Unread 18-03-2016, 18:34
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Re: Camera freeze up during matches
Size is the knob you want to turn.
You can check on the amount of data being sent by the camera to verify that it's below 7mbps.
1. Close other things running on the driver station
2. Open Resource Monitor and verify that you're not using much network bandwidth (Network tab)
3. Start the robot and the driver station
4. Look at network activity in Resource Monitor. Is it above 7mbps? If so, tweak settings to lower resolution or frame rate.
Personally, I wouldn't let my team run at more than about 6.5 mbps.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 19-03-2016, 22:30
FRC #4277
Thanks for the tip.
When we ran the camera feed on the java dashboard - we were at close to 7 mb
When we use the default dashboard - we were less than 1 mb
Very strange.
I guess we will have to see what it does on the practice field when we get to our regional.
