Go to Post (I'm sure that Dave is holding his breath for "welding with Jello".) - jgannon [more]
Unread 18-03-2016, 19:15
Charlie2016's Avatar
Charlie2016 Charlie2016 is offline
AKA: 8 mile
FRC #3542 (SPEED)
Charlie2016 is an unknown quantity at this point
2 usb camera toggle in labview
My team has found that we have a use for both ends of our robot this year. I have heard of teams toggling between cameras in labview but I have not figured out how to do so. If anyone could post a picture of this or leave an example it would be greatly appreciated. We are using 2 ms lifecams if that affects anything.
Unread 18-03-2016, 22:32
teku14's Avatar
teku14 teku14 is offline
http:
FRC #2614 (MARS)
teku14 is a jewel in the roughteku14 is a jewel in the roughteku14 is a jewel in the roughteku14 is a jewel in the rough
Re: 2 usb camera toggle in labview
Try this http://www.chiefdelphi.com/forums/sh....php?p=1532343
Unread 18-03-2016, 22:35
TogetherSword8 TogetherSword8 is offline
FRC #0888 (Robotiators)
TogetherSword8 is an unknown quantity at this point
I know there is a way to get both camera streams through usb. Look at the example code, and when it initializes camera, it has you choose between usb 0 and camera-team.local. If you change the camera-team.local to usb 1, it will be the second camera. If you double this initialization code for usb 0 and usb 1, you can choose which camera reference to read.
As for how to forward this image to the robot, I am not sure, but my idea would be to use an udp connection and send over the image at the end, choosing between the two. There is probably a more efficient way, but I don't have a robot with me such that I could test any potential solutions.
I program a robot. Which means I write code and everyone gets mad at me when something doesn't work, even if I am the only one that knows it doesn't work. The key part to know is that the robot never works.
