Go to Post Remember, GP doesnt just need to apply to FIRST; if we all apply in our lives as a whole, the world will be a better place. - Dillon Compton [more]
Unread 18-03-2016, 22:43
esatterfield32 esatterfield32 is offline
FRC #5962 (perSEVERE)
Team Role: Electrical
Rookie Year: 2015
esatterfield32 is an unknown quantity at this point
Re: Scaling Winch Motor Help
When you scale with this system, does it fall back down after the robot is disabled? Also, how heavy is your robot? We have a 60lb robot (excluding our potential scaling system) and I was curious how many motors we should use.
Unread 18-03-2016, 22:50
Rookie Year: 2015
Originally Posted by MaGiC_PiKaChU View Post
I see you plan on making a similar system to ours.
we had a single 775 from vex at first. i believe geared down 75:1
we doubled that at GTCR, now 2 775s, same ratio.
Unread 18-03-2016, 22:53
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Ours is two 775pros on two 49-1 versaplanetaries facing each other with a 3 inch wide 1 inch diameter spool between them. A switchable 1/2 inch rachet wrench keeps it from back driving. its pretty fast.
2016 Central Illinois Winner. Curie Division finalist
Unread 18-03-2016, 23:12
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
You should check out this data from VEXPRO on maximum loading on the VersaPlanetary gearboxes. Be sure you are within the design limits of the gearboxes for the motor / gear reduction you are using.
http://content.vexrobotics.com/vexpr...s-20151221.pdf
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 19-03-2016, 00:33
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Is anyone using BAG motors for winching this year? I'm hearing a lot of CIMs and RS775Pros but JVN's Spreadsheet tells me that it is doable with the BAG motors. Just curious.
Unread 19-03-2016, 10:56
Rookie Year: 2015
with two pg71 motors is it doable? We have two on hand that are gears 71:1 but when we put it in the JVN spreadsheet it says it's going to go too slow, maybe I'm putting the information in wrong..
Unread 19-03-2016, 13:03
Originally Posted by esatterfield32 View Post
with two pg71 motors is it doable? ...when we put it in the JVN spreadsheet it says it's going to go too slow, maybe I'm putting the information in wrong..
The motor in the 2016 FRC motor spec sheet that is listed as "Mates with PG71 gearbox" is the AndyMark am-2161 RS775-5. That motor's max power is only 37 watts.
See Richard's post#4 in this thread.
