Go to Post Now, if that team were to split...would it be dividing by zero? - Karibou [more]
Unread 18-03-2016, 17:03
Bernstern Bernstern is offline
FRC #2141 (Spartonics)
Rookie Year: 2015
Bernstern is an unknown quantity at this point
Porting Tower Tracker to CPP
Does anyone have a good way to translate (or if it already works its ok) the TowerTracker.java program into CPP to run on a Coprocessor (Tk1)?
Programmers, a species indigenous to robotics that can convert caffeine into code.
Unread 18-03-2016, 17:20
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Re: Porting Tower Tracker to CPP
I ported it to c++ here: https://github.com/team2053tigertron...bot/src/vision
It's a little rough, but worked for us in Pittsburgh very well.
Unread 18-03-2016, 17:35
lethc's Avatar
lethc lethc is offline
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
lethc will become famous soon enough
Just a heads up, we tried running TowerTracker on a TK1 at Greater Kansas City and spent literally all of Thursday trying to get it to communicate over ethernet. We got the calibration images we needed from the field about 30 seconds before we had to leave. The competition router image disables DHCP, and we hadn't planned for this. To fix it we had to set all of our devices' (Driver station, TK1, RoboRIO) IPs to static which took awhile because we hadn't planned for it.
Basically if you're planning on communication with the Jetson over ethernet make sure you account for the fact that the router competition image is different from the 'home use' image. I really don't want anybody to go through what we went through on Thursday
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
Unread 19-03-2016, 07:17
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
No it doesn't? The field uses pure DHCP communications except for the router. You get assigned a dhcp IP address in the range of 10.xx.yy.zzz in contrast to the 169.254.xx.xx address in the pits.
Unread 19-03-2016, 12:54
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
We ran into the same problem at our event. The competition bridge configuration doesn't disable DHCP, it just doesn't have a DHCP server (because it expects to use the one on the field). This causes the driver station and robot to get an autoconfigured IPv4 address (169.254.x.x), but the Jetson does not.
We fixed this at the competition by using static IPs, but it could likely also be fixed using avahi-autoipd (see: https://wiki.ubuntu.com/ZeroConfNetworking) to assign an IP without DHCP, but I have not tried this yet.
Unread 19-03-2016, 15:39
jreneew2's Avatar
AKA: Drew Williams
So when giving devices that run network tables an ip you can give it roboRIO-XXXX-frc.local? Or a static ip that you set?
Unread 19-03-2016, 16:31
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
The former if you are using DHCP, the latter if your team is moved to static ip for some reason (the former still works in the second case but it is more reliable to go straight to the IP address if it is known)
Unread 19-03-2016, 17:08
jreneew2's Avatar
AKA: Drew Williams
Ok thanks!
Unread 20-03-2016, 14:30
Rookie Year: 2015
You're a lifesaver but how do i send the distance to center (all we need) over networktables and into our java code?
-Freshmen
Unread 20-03-2016, 14:43
jreneew2's Avatar
AKA: Drew Williams
Our team is actually working on that now! Except we are using a raspberry pi. For us, we compiled the network tables code onto to pi and included in our code. Then you just send the data as with any other code. Here is a wpi screensteps page I found that was helpful.
https://wpilib.screenstepslive.com/s...client-pc-side
Unread 20-03-2016, 15:39
Rookie Year: 2015
Thanks a ton, we spent the last week trying to flash our tk1 then trying grip but this may be our answer
Unread 20-03-2016, 15:53
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
We went through the same thing as you folks on that Thursday!😬 Spent 3 hours on it!
Unread 20-03-2016, 16:01
jreneew2's Avatar
AKA: Drew Williams
So would you say it is better to set static ips for everything for competition? I have seen conflicting information about static and dynamic ips.
If so, how do you go about setting ips to static on the roborio, raspberry pi etc?
Unread 20-03-2016, 16:05
waialua359's Avatar
AKA: Glenn
According to the manual, it is not recommended. However, FTA finally said to go ahead and setup using a static IP and gave us a range to work with. I'm not the Control Systems person, but I can tell you that he tried troubleshooting everything to get it to work. It was our only option.
It's worked fine for 2 events already.
Unread 20-03-2016, 16:53
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is online now
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
What range did he give you? I want to make sure ours is good-to-go beforehand so we won't have to debug comms during practice matches.
Cortechs Robotics 2014-Present
Mechanical, CAD
