Go to Post make your robot so it's not a problem and it won't be a problem - pfreivald [more]
Unread 20-03-2016, 19:13
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Conveying along chain
I've been googling around about this for the past couple of hours, but I can't seem to wrap my head around how teams are utilizing chains for linear motion. Currently, the best item I can find to do something like this would be something like this, but my gut tells me that these would be rather fragile for anything more than a few pounds. If I wanted to move a load along a chain, how would I best accomplish this?
Unread 20-03-2016, 19:22
hectorcastillo's Avatar
hectorcastillo hectorcastillo is offline
Former Driver and Captain for 3481
FRC #0125 (NUTRONs)
hectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to all
Re: Conveying along chain
You can put bolts through the holes in the links to fasten whatever you want to move with the chain. I believe #4 bolts work for this.
365 Decontaminators (FLL) 2011 - 2012
6221 Panther Bots Alpha (FTC) 2012 - 2016
3481 Bronc Botz (FRC) 2012 - Present
125 NUTRONs (FRC) 2017 - Present
Unread 20-03-2016, 19:23
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
We used home made versions of what you linked above on our bot last year to lift the totes. It worked alright but wasn't great. The issue we found with them is if we jammed our mechanism, it would cause of few of the attachment links to break off (they're a master link with a flange on either side basically). If you broke your chain properly (not using an insane amount of master-links) it might be feasible. Might need to do some load testing though.
What we found works really well on the other hand though is just passing bolts through the holes in the chain and bolting it to the mechanism we are moving. As long as you aren't needing to have the chain loop around the sprocket, this method is clean and easy to implement.
FRC #5202
And that will hold? Is there a stronger alternative?
Sounds neat! I do wonder about the reliability of that but it sounds like it might work. Thanks!
Unread 20-03-2016, 19:26
DonRotolo's Avatar
Back to humble
FRC #0832
Aside from those McMaster parts, there are several ways to attach to a chain - some of which can be as strong as the chain itself.
Aside from the example above, how about a loop around a small sprocket, and pull using the center bore of the sprocket? The chain can be held on with a zip tie, since it's not under stress.
Can you think of other ways?
Unread 20-03-2016, 19:30
FRC #0125 (NUTRONs)
We had three #4 bolts going through our chain on our climber and it successfully lifted over 120 pounds. That being said, we only ran it maybe four or five times in total on our practice bot, and we haven't gotten to see what the strain of an entire competition would do to it, but in short, yeah it works. You can also put more bolts in or have multiple chains to help distribute the load.
Unread 20-03-2016, 19:43
FRC #5202
Huh, now that's an interesting idea. Thanks! We could use an L-Bracket or something to hold the sprocket to the plate. Thanks!
Neat. Thanks! Questions like this always remind me why I'm the programmer and not the project manager.
Unread 20-03-2016, 19:47
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Bigger chain, bigger bolts. #35 chain fits #8 bolts, I think. Not sure if the extra weight is worth the gain in strength though.
Unread 20-03-2016, 19:53
FRC #0125 (NUTRONs)
Thanks for bringing that up, Chak. I completely forgot about #35 chain. We used #25 to make our climber as light as possible, but #35 is definitely a great and probably more reliable option.
Unread 20-03-2016, 19:54
Steven Smith Steven Smith is offline
FRC #3005 (RoboChargers)
Steven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond repute
VexPro sells a gusset with the intended use case. You could easily make something similar, but their drawings explain it well.
http://content.vexrobotics.com/vexpr...00-Release.PDF
2013 - 2017 - Mentor - Robochargers 3005
2014 - 2017 - Mentor - FLL 5817 / 7913
2013 - Day I Die - Robot Fanatic
Unread 20-03-2016, 20:05
FRC #5202
Neat! Thank you!
Unread 20-03-2016, 20:10
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Here is an example of what we did for our elevator last year. We used T-Gussets bought from Vex and bent them 90 degrees to give us plenty of mounting room. To attach the gusset to the chain we used two #8 bolts, which fit through #35 chain (use more #4 bolts if you are using #25 chain), which seemed to provide plenty of support.
Unread 20-03-2016, 20:55
jnicho15's Avatar
jnicho15 jnicho15 is offline
AKA: Dan
FRC #0548 (Robostangs)
Team Role: Electrical
jnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nice
548 used those McMaster attachment links last year to mount our tote hooks to our lifting chain (which also had a guide rail). This year, we are using them to hold the end of the springs that balances our arm.
2014: MIHOW DCA, Finalist
2015: MISOU Finalist; MILIV DCA, Winner; MIBED Winner; MICMP Winner, Engineering Excellence
2016: MISOU KPCB Entrepreneurship Award; MILIV DCA; MICMP 16th Alliance- 8-F winner
Unread 20-03-2016, 21:32
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Link to mcmaster's selection of attachment links. Only for #35 (or larger) though.
Unread 20-03-2016, 22:17
Dominick Ferone's Avatar
Dominick Ferone Dominick Ferone is offline
FRC #5030 (The Second Mouse)
Dominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really nice
I've been googling around about this for the past couple of hours, but I can't seem to wrap my head around how teams are utilizing chains for linear motion. Currently, the best item I can find to do something like this would be something like this But my gut tells me that these would be rather fragile for anything more than a few pounds. If I wanted to move a load along a chain, how would I best accomplish this?
We used these back in 2013, and we had hardened steel 6-32 bolts. They could withstand 600 pounds of force before sheering. We never had a problem with them. We actually damaged the hook and the chain and bolts were fine.
2010-2013 Team 353 The POBots - Student, 2014-present Alumni.
2014- present Team 5030 The Second Mouse - Mentor and Founder.
