Re: 775 pro likely to pop breakers?
It might be easier to make a recommendation if we could see what it is you are trying to power with the motor, and if you let us know what gear reduction you are using, and roughly what the load is on it.
If you set things up right, the motor won't ever be in a situation where it will stall.... |
