Re: Conveying along chain
VexPro sells a gusset with the intended use case. You could easily make something similar, but their drawings explain it well.
http://content.vexrobotics.com/vexpr...00-Release.PDF |
Here is an example of what we did for our elevator last year. We used T-Gussets bought from Vex and bent them 90 degrees to give us plenty of mounting room. To attach the gusset to the chain we used two #8 bolts, which fit through #35 chain (use more #4 bolts if you are using #25 chain), which seemed to provide plenty of support.
![]() ![]() ![]() Last edited by Monochron : 20-03-2016 at 20:12. |
548 used those McMaster attachment links last year to mount our tote hooks to our lifting chain (which also had a guide rail). This year, we are using them to hold the end of the springs that balances our arm.
Link to mcmaster's selection of attachment links. Only for #35 (or larger) though.
