Go to Post Stupid rules are not meant to be broken; they're meant to be changed. Unless and until they are changed, breaking them is wrong. - Alan Anderson [more]
Unread 20-03-2016, 21:14
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
Help with Joystick command
We are having an issue where a joystick command (Left and right trigger on XBox controller) are not working properly.
In the driver station, i can push the button and the signal is being read (i can see the signal on the screen) but when we probe the code, no signal is read... i cannot figure this thing out.... We switch to a different controller and we have the same issue so we are pretty sure its in the code....
Unread 20-03-2016, 21:52
whitetail's Avatar
whitetail whitetail is offline
FRC #5407 (Wolf Pack)
Team Role: Operator
whitetail is an unknown quantity at this point
Re: Help with Joystick command
What programing language are you using?
FRC Team 5407 -Driver, Programmer and Head Control Systems Engineer
2015 MAR Championship Rookie All Star Award
2015 MAR Hatboro-Horsham District Rookie All Star Award
2015 MAR Hatboro-Horsham District event Winner(Thanks 2590, 2607)
Unread 20-03-2016, 21:55
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Can you post a snapshot of your code and a description of what you expect it to be doing?
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 20-03-2016, 22:11
Matt-T-FRC Matt-T-FRC is offline
Electrical Engineering Student
AKA: Matt Tisovic
FRC #6181 (Northwest State Cryptic Cyborgs)
Team Role: Electrical
Matt-T-FRC is an unknown quantity at this point
Coach Seb,
I had a chance to do a little work to your program since we last talked. I am posting a vi sniplet of your teleop code with the automated arm and winch removed. Use this as an example and go from there for further trouble shooting.
Unread 20-03-2016, 22:39
wt200999's Avatar
Texas Instruments
AKA: Will Toth
Originally Posted by Matt-T-FRC View Post
Coach Seb,
Your wires appear to be... missing...
Any reason why y'all are using the "Array to Cluster" and "Unbundle by Name" instead of using "index array" directly?
Unread 20-03-2016, 22:58
AKA: Matt Tisovic
Wow, it shows up in Teleop, I posted an updated version. Also I use array to clusters and then unbundle by name because that is what I am use to using and haven't completely adapted to using array to clusters yet. It also makes it a little easier to read.
Name:	5860 Teleop Ideas UPDATED.png
