Go to Post My crotchety old person opinion is that it should be illegal to try to win the award. Do things because you like doing them or because it helps others. Don't do things to win awards. - Madison [more]
Unread 20-03-2016, 21:45
AMendenhall AMendenhall is offline
FRC #3925
AMendenhall is an unknown quantity at this point
Re: GRIP Deploy Error
We're getting new errors on deploy...
We commented out this code and pushed:
table = NetworkTable.getTable("/GRIP/Mar20");
		try {
			new ProcessBuilder("/home/lvuser/grip1x.log").inheritIO().start();
		} catch (Exception e) {
			DriverStation.reportError("\n\n\n\nGrip Has Errored!\n\n\n\n", true);
Then we deployed a pipeline that creates a webcam on port 0 (the usb webcam on the robot is "cam0") and publishes the framerate as a number. This is the error message we get when we deploy:
/usr/local/frc/JRE//bin/java -Xmx50m -XX:-OmitStackTraceInFastThrow -XX:+HeapDumpOnOutOfMemoryError -jar '/home/lvuser/grip.jar' '/home/lvuser/project.grip'
Mar 21, 2016 1:39:23 AM java.util.logging.LogManager$RootLogger log
CONFIG: Configuration done.
CONFIG: GRIP Version: 1.3.0-rc1
platform: /Linux/arm/
Mar 21, 2016 1:39:29 AM edu.wpi.grip.core.operations.networktables.NTManager lambda$new$32
SEVERE: NetworkTables: TCPConnector.cpp:157 select() to  port 1735 error 111 - Connection refused
Mar 21, 2016 1:39:30 AM edu.wpi.grip.core.Main start
INFO: Loading file /home/lvuser/project.grip
Mar 21, 2016 1:39:31 AM edu.wpi.grip.core.GRIPCoreModule onThreadException
SEVERE: Error from Thread[main,5,main]
java.lang.UnsatisfiedLinkError: java.io.IOException: No space left on device
	at org.bytedeco.javacpp.Loader.loadLibrary(Loader.java:613)
	at org.bytedeco.javacpp.Loader.load(Loader.java:438)
	at org.bytedeco.javacpp.Loader.load(Loader.java:381)
	at org.bytedeco.javacpp.opencv_core.<clinit>(opencv_core.java:10)
	at java.lang.Class.forName0(Native Method)
	at java.lang.Class.forName(Class.java:340)
	at org.bytedeco.javacpp.Loader.load(Loader.java:413)
	at org.bytedeco.javacpp.helper.opencv_core$AbstractArray.<clinit>(opencv_core.java:109)
	at edu.wpi.grip.core.operations.opencv.MatFieldAccessor.<clinit>(MatFieldAccessor.java:12)
	at edu.wpi.grip.core.operations.Operations.addOperations(Operations.java:36)
	at edu.wpi.grip.core.Main.start(Main.java:44)
	at edu.wpi.grip.core.Main.main(Main.java:32)
Caused by: java.io.IOException: No space left on device
	at java.io.FileOutputStream.writeBytes(Native Method)
	at java.io.FileOutputStream.write(FileOutputStream.java:307)
	at org.bytedeco.javacpp.Loader.extractResource(Loader.java:306)
	at org.bytedeco.javacpp.Loader.loadLibrary(Loader.java:563)
	... 12 more
