Go to Post The rules also never explicitly say that I can't park a Boeing 747 right in the middle of the play field and use it as an obstacle for the other alliance. But after a little thought, something tells me that I probably should not do it. - dlavery [more]
Unread 20-03-2016, 22:38
brk brk is offline
FRC #0180
brk is an unknown quantity at this point
GRIP publish rate
I understand that GRIP will read a frame from the camera and pass it through a pipeline. I have two questions related to that.
If the output image of one stage is handed to two other modules like a split-Y or branch, do the two operations happen in parallel? For example, taking a resized image and sending it both to HSLThreshold as well as sending it to the driver station, will both the calculations and network write happen in parallel?
Second, is there a way to find out how often GRIP updates/publishes a contours report to NetworkTables? I see in the code that the pipeline scheduler is set to 1ms, but I believe the capture and processing take much longer than that. I'd like to know how often the values should be read/consumed by the roborio.
Unread 21-03-2016, 12:02
blackrootbot blackrootbot is offline
FRC #5489
blackrootbot is an unknown quantity at this point
Re: GRIP publish rate
I am curious about this too.
